SOURCE: HP 6940 Deskjet Low Ink
It is not uncommon for a refilled HP ink cartridge to register as empty. If it was otherwise filled properly, it should yield the correct number of pages, but you may not be able to get the warning light to go out.
You can try tapping the cartridge on a hard surface. This only works sometimes. Be careful not to splash any ink.
I hope this helps.
SOURCE: Where do I find the ink volume indicator on the hp
SOURCE: HP 6940 Deskjet driver not installing WINDOWS 7
hi,the reason why it most probaly comes with that error is that the driver is not meant for windows 7,so go on line check hp site, printer drivers and download.
SOURCE: how do you install the hp deskjet 6940 printer
You can find the drivers of the printer using the link below:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=468003&lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=468001
SOURCE: DeskJet 940c InkJet Printer: I have an hp deskjet 940c printer. The orange lig...
the moving ink frame is probably pointing to a symbol such as replace color ink( three dots on ink cartridge picture). Replace color ink. You are probably printing your black and white documents with colored ink--always select black or greyscale.
