Cell Phones Logo
P
PAPPUSINGH Posted on Jul 15, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Backup battery low
YES
W.L.
Level 3:
  • Master 2,511 Answers
  • Posted on Jul 15, 2014
W.L.
Master
Level 3:
Answers
2511
Questions
Helped
524308
Points
8345
1helpful
I tried using 3 AA NiMH batteries (total DC V=4.2, 1600mA) as a backup/charger for my HP Ipaq 612c battery. I inserted a resistor (4.7 ohms) in the circuit to reduce the current. The red light charging...
You built one of these too, eh?
Yes, there can be a problem doing this. First off, 3 AA batteries does not equal 4.2 volts, they are 1.2volt nominal so 3 * 1.2 = 3.6volts. When they are just off the charger, terminal voltage will be closer to 1.5v, so 1.5*3 = 4.5 volts.
Using ohms law, E=I * R, we can find your current as I = E / R or I = 4.5v / 4r7 as .95Amps (almost a full amp) that you would see worst case. The resistor is doing nothing for you.
The reason that the charge light blinks intermittently is because the charge controller (lithium battery, right?) is pulsing due to low voltage.
Try this: Take *6*, yes, 6, AA batteries, your choice of chemistry, and put them in series. That will give you a nominal (alkaline) voltage of 9v. Connect a low dropout 5v regulator such as an LT1117-5. Then you will be able to use your battery backup much more effectively.
On a different note, I used 4xAA (NiMH) and powered my ipaq 3650 directly. Worked great. Your mileage may vary though.
Aug 27, 2010 • Cell Phones
MC1000 scannerBackup battery very low
You must disasemble de unit. There is a Ni-Mh 3.6v 15mAh batery inside at the bottom of the unit.
1helpful
3answers
Battery backup is too low..
This may happens sometime with charger ,as i have the same problem and i replace the charger---i shown the mbile HTC authorised center
HOW TO CHANGE OR CHARGE THE BACKUP BATTERY?
y hp6365 keeps telling me that i my backup battery is low..i keep charging my phone but the only the main battery is charging..how do i charge or change the backup battery?
The battery backup is very low
Looks like either the devices connected to the backup battery are consuming too much power than that backup can handle or the backup battery is getting worn-off. You may need to change the batteries or take-off some load (remove some devices that consume power) from the backup battery.
I'm getting a message - backup battery very low etc -
you can buy a Backup battery for the axim X3 series on Ebay for about 17.00 that includes shipping. best price Ive seen
Error message "Backup Battery Very Low"
The MobilePro 900 back up battery is low and should be replaced. The battery is a CR2032 coin-cell battery, which is very common and can be purchased at most department and drug stores. Refer to section 1-7 of the "MobilePro 900 Handheld PC's User's Guide" for detailed replacement instructions.
1helpful
When should I replace my backup battery?
The back up battery should be replaced immediately upon seeing the message "Backup Battery Very Low - Your back up battery is very low or missing. Data loss may result from failure to replace the battery very soon. Consult the manufacturer's instructions for directions on replacing or charging the backup battery." Warning: It is important to note that the back up battery in the MobilePro 900 is not rechargeable, thus, to prevent data loss, it is important to change the back up battery immediately when this message is displayed.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
