Electrolux EW30ES65GS 30" Slide-in Electric Range with 5 Radiant Elements, 4.2 cu. ft. Self-Cleaning... Range Logo
G
Grant Meyer Posted on Jul 15, 2014
Electrolux EW30ES65GS 30" Slide-in Electric Range: Error Code E15 shows, clears and comes back every 20 seconds.
My stove top touch control panel flashed error code E15, beeps. when locked, it initially goes away, then comes back, E15, tries to reset itself, is normal for 10 seconds, then E15 all over again. I dont use the oven ( 5 times in 2 years ) and use the iduction elements every day. I was hoping that after several years now, maybe somebody has been able to fix this problem? Thank you, Grant, [email protected]
5 Related Answers
Anonymous
  • 15 Answers
  • Posted on Mar 21, 2009
SOURCE: wave touch panel comes out of sleep mode by itself
Your range should have a two year part and labor warranty so contact Electrolux to schedule service. They will preorder and ship you the parts prior to a servicer arriving.
Anonymous
  • Posted on Apr 30, 2010
SOURCE: Error Code 5F displayed. Oven
hold - and + button at the same time for few seconds until it works again.
Anonymous
  • 2605 Answers
  • Posted on Sep 09, 2011
SOURCE: My new Slide in electric range...I just spilled
Hello, welcome to FixYa.
I understand you have the new Electrolux/Frigidaire EW30 series slide in range, correct ? I also understand based on your post you're getting the E11 error message. According to the service manual, here's what it is and what you can do...
macmarkus_929.jpgIf you pull/slide the unit away from the wall and unplug it or turn the house breaker off for 30 seconds to a minute the control should reset.
That should do it...Let me know how you make out and if you need anything further I'll be glad to help in any manner I can. Good luck.
Regards,
Macmarkus :)
Anonymous
  • Posted on Jan 01, 2012
SOURCE: I have a Electrolux range oven and I did a self clean and it faulted through the cycle. IThe code that comes up is "--" which the manual says it mean cooktop lock. I fred to unplug / turn breaker of
reheat the oven and then put it in the washing machine
chrispolkele
Electrolux
  • 4342 Answers
  • Posted on Aug 14, 2012
Our people make the difference
    Verified Fixya Pro
    SOURCE: e15 error code
    You have an error between the control board and electronic oven control. 1. Test the harness and connections from EOC connector P16 to Oven Relay Board J2. 2. Replace the Oven Relay Board. 3. Replace the EOC.
    How to fix error code 15
    Hi friend, thank you for your inquiry!
    Based off your post your Frigidaire range is providing you an "E15" error code. "E15" stands for a signal loss between the oven relay and EOC (Electronic Oven Control) I would perform a reset on your appliance. You can do that by disconnecting power to your range by unplugging the power cord or flipping the household circuit breaker for roughly ten minutes.
    If that does not correct the issue it could mean that your oven relay board or electronic oven control may need to be replaced. If that is the case I would suggest seeking assistance from a professional to avoid any unnecessary part purchases. -Matt
    What does E15 fault in a electrolux stove mean?
    Thank you for your inquiry, friend!
    I understand that you are looking for the meaning of "E15" on your Electrolux range. "E15" stands for ESEC self-test failed, which could either mean and issue within your UIB (User Interface Board) or relay board. I would recommend having a professional come out to diagnose and repair your appliance. Best of luck. -Matt
    Remove and replace the control display
    Good Afternoon Mr. Stevenson,
    I see that you are looking for instructions on how to remove and replace the control display on your Electrolux range, model# EW30ES65GS. First, I do suggest having an authorized technician to make repairs such as these, so you're not left with any other damage to your appliance. Second, while I don't know of an actual instruction manual that will help to replace the control display panel, I have attached a link that will take you to a parts breakdown manual.
    ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/5995621363.pdf
    -Best Regards-
    WP
    There is sonorous alarm and the control panel describes an error E15. The problem is that the top of the stove can't be used because of that.
    Hello Flor, thank you for allowing me to assist you!
    If you are getting an error code E15, it usually means that your range is possibly experiencing a communication problem. One can be either between the cook top control and user interface or clock and thermal. You may try resetting your range by disconnecting the power to the unit or flipping the household circuit breaker off. It is important to wait roughly ten minutes and then turn your appliance on. This often clears most false error codes. If resetting the unit proves to be ineffective, I would suggest contacting a professional to move forward accurately since this is not a typically do it yourself job.
    7helpful
    E15 error code
    My oven is beeping on an E11 error code on my electrolux range. How do I stop this?
    E11 indicates a communication error where a technician needs to diagnose the control board.
    Wave touch panel comes out of sleep mode by itself
    Top Electrolux Kitchen Ranges Experts
    ZJ Limited
    ZJ Limited
    ADMIN Andrew
    ADMIN Andrew
    john h
    Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
