Question about Sony KDF-E42A10 42 in. LCD Television
Tv stays on for about 1.5 minutes and turns off
TV will not stay on. It will turn on and after a
Problem with your TV's picture tube,Replaci it
Feb 15, 2011 | Philips 32PT5441/37 32" TV
Tv staying on standby remote and side buttons nt working
Unplug the tv for 1 minute, plug it back in this works 1% of the time. If the tv still does not turn on and the menu doesn't come up then the tv will need to be serviced.
May 07, 2010 | Televison & Video
Screen and sound problem?
sony 2005 kdf e60a20 tv---turns on and off every 2-3mins...green power lite stays on no blinking
Mar 27, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
Tv won't stay on
sounds like lamp failure. the lamp is consumer replacable.
Aug 10, 2009 | Televison & Video
Tv will not stay on only for 1 min. then turns red and off
Symptoms shows Red Tube is defective and needs replacement.
Please confirm model number with serial to look for Red Tube in stores.
Thank you.
Dec 17, 2008 | Sony KP-51HW40 51" Rear Projection...
Picture goes out, sound stays on
According the information I believe your backlight might went out. call 323-767-6030 I will go through with you for your tv.
Dec 14, 2008 | Astar LTV-3201 32 in. LCD Television
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Powers off after 15 seconds to 1 minute
solder issue at the flyback. try resoldering the flyback
May 17, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
Help
1)in side ur tv kit    there  sould be  loose connection  at circuit tracks     otherwise    check  EHT SECTION    means   check  ABL signal  from  EHT TO CROMA IC .
2)if ur tv is  stays on  for 5 minutes  only with sound and not with video    then    replace   vertical IC  with the same number
this will solve ur problem
thanks
Mar 02, 2008 | Symphonic SC309C 9 in. TV/VCR Combo
Sony KDF-E42A10 42 in. LCD Television Logo
89 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
