Jet 3 Ultra Power Chair Logo
A
Anonymous Posted on Jul 14, 2014
Do yall repair a jet 3 power chair
I dontknw what is the problem with the chair it wont charge or it wont pick up the speed
5 Related Answers
Anonymous
  • 40 Answers
  • Posted on Apr 10, 2009
SOURCE: jet3 ultra power chair wont charge
If you have access to a voltmeter,put it on your battery then plug in the charger; if the voltage rises that will tell you that your charger is working.
arrius
Randy Breeden
  • 3 Answers
  • Posted on May 14, 2009
SOURCE: need to remove the bad batteries Jet 3 power chair
Hello Donald ,
You may have solved this problem by now ,but just in case you have not, here goes.
Make sure the chair is turned off and engauged in the drive mode meaning not in the free wheeling mode. This way it will not roll around on you during the battery change out.
Go to the rear of the chair and slightly turn the two black plastic lock pins,one on each side they actually lock the small )) shaped cover in place. Turn these with your fingers or you can also insert a dime in the slot on top of each pin to turn them . You will be able to tell when they have unlocked as the )) shaped cover will be loose. Lift the cover up and under it you will find the battery connector, unplug it and leave the cover off for now.
Next ,move to the front of the chair and just to the rear of the footplate you will find a locking pin that runs through the lower rear bar of the footplate as well as the chair frame itself . Pull this pin completely out. Once done you should be able to pull the entire footplate assembly out torward you, Black plastic front cover included. Once you have it pulled outward lift it upward and it should lift completely off the chair. This done , you should actually be looking at the front battery which is sitting in a black plastic tray. Gently but with a firm grip grab the tray anyplace you can and slowy begin to slide it out from under the chair torward you taking care not to tangle the battery connector at the rear with any other wiring on its way out. Once you have the tray slid out into the open ,you will be looking at both batteries after which you will need to unhook the straps that secure the Batteries to the tray after which you will need grab your wrenches and remove the battery harness itself from each battery. You may want to do just one battery at a time this way you'll have less wiring to keep track of when wiring in the new Batteries. The Batteries in your Jet 3 are a size known as U-1 deep cycle sealed maint. free batts, You can use either Gel Cell or seale3d LA replacements . Though they are much cheaper, you cannot use lawn tractor batteries. Though they look the same the internal technology between medical powered mobility batteries and tractor batteries are entirely different. The latter would only run your chair for maybe a half hour or so before needing charge.
Take great care to make sure your wiring hookups are correct and that you position the rear connector plug to the rear of the tray. This way you will be able to locate it easier once you have slid the tray back in under the chair and it is time to go to the rear of the chair and reconnect that plug. As for everything else ,reattach it in reverse of the way you removed it including remembering to slide the lockpin back into the front footplate frame. Give a tug on the footplate when done to make sure it is locked and secure.
In closing I offer this valuable advice : When working with any of these batteries, always were safety glasses or goggle and gloves (terminals are lead). I also advise removal of metal rings ,watches, bracelets etc that could create a short when reaching in and around the battery terminal. Take great care with your tools and wrenches in making sure you keep and eye on both ends of the tools at all times. This way you will not accidentally cross the posts of the battery. Take your time ,use proper safety technique and you'll do fine. The following is Pride Mobility's step by step for battery change out and is basically the same as I have sent . Can never have to much info but can always find yourself with not enough. Take Care
To replace the batteries:
1. Turn off the power to the controller.
2. Make sure that the power chair is in drive mode. See III. "Your Power Chair."
3. Turn the rear shroud fasteners one-quarter turn in any direction. See figure 6.
4. Remove the rear shroud.
5. Unplug the battery connector. See figure 26.
6. Remove the retaining pin from the foot platform and lift the platform up and away from the power base. See figure 19.
7. Slide the battery tray forward.
8. Unfasten the reusable strap around the front battery.
9. Disconnect the wiring harness from the front battery.
10. Remove the front battery.
11. Unfasten the reusable strap around the rear battery.
12. Disconnect the wiring harness from the rear battery.
13. Remove the rear battery.
14. Place a new rear battery on the battery tray. Make sure that the terminals are facing forward.
15. Fasten the reusable strap around the rear battery.
16. Connect the wiring harnesses to the rear battery.
Anonymous
  • 37 Answers
  • Posted on Jun 24, 2009
SOURCE: Jet 3 Ultra won't charge
You can find the Fuse behind the foot rest. Take the pin located under the foot rest, and the casing will come off exposing the fuse.
Anonymous
  • 29 Answers
  • Posted on Sep 07, 2009
SOURCE: pride mobility Jet 3 Ultra Power Chair 7 flashing
a 7 Flashe code. There is a joystick fault. Make sure the joystick is in the center position and then power off and on again. Check all your couplings. make sure when turning on the unit you only mash the power button for 1 sec. 2-3 sec will put the unit in "Lock out mode".
This ierror will also be present if the joystick is off center when powered up. If you experience these symptoms, you must first make sure there is no physical damage to the joystick preventing it from returning to the center position. Then turn the power off and back on again (making sure the joystick is not depressed in any direction. If the joystick repeats this error, the controler much be replaced. [email protected]
Anonymous
  • 6 Answers
  • Posted on May 12, 2010
SOURCE: need a wiring diagram for jet 3 power chair
Look here: http://www.pridemobility.com/pdf/Owners_Manuals/US_Jazzy/US_Jet_3_ultra_om.pdf
Pride Jazzy Jet 3 Ultra Electric Wheelchair. Fuse keeps blowing I was given a Jet 3 Ultra for my mom .. I bought new batteries and installed them.. charged them over night ..
Question edited for clarity.
You have a dead short somewhere. You need some electrical knowledge and a digital multimeter for testing. Take all the covers off. Look for wiring that has rubbed through and touching or melted. Disconnect one of the motors and replace the fuse. If it still blows, reconnect that one and disconnect the other motor. If one motor doesn't blow and the other does, you know you have a faulty motor. If neither stop the issue, then you move up to the controller and look up there. With a meter you can check for shorts within the motors, as well as grounds.
Or just take it to a Service Centre and have it repaired and serviced properly.
Basic troubleshooting
INFINFB2045 Jet 3 Ultra Troubleshooting
Pride Mobility https://www.pridemobility.com > pdf > infinfb2... PDF troubleshooting instructions for the Jet 3 Ultra Power Chair. This information is to be ... A blown charger fuse can cause the charger inhibit to activate.
Can i get yall phone number so i can call yall
The best way to get a phone number is to call the manufacturer and ask for a phone number to a tech local to you. They have a database of all the techs that are authorized to work on their product. Call 1-800-800-8586 to get a tech to talk to near you. Or you can talk to a tech in their technical service department. Ultimately you will probably be directed to a nearby tech but at least you will be getting answers.
How do you increase the speed in Jet3 power chair
I take it you are talking about increasing the maximum speed beyond the maximum the chair is set for now! the max listed speed for the jet 3 is 4mps, so if your chair is doing that there is only changing a load of hardware to increase speed past that (it is very costly) if your chair is second hand it may be that the chairs programming has been changed to reduce the max speed say for in-door use or for elderly with slow reactions to better control the chair, if that is the case it depends on the controller you have it would need a programmer box, you can buy these on ebay and the like or you could take it to a mobility shop and see if they will change it, a lot of these shops will offer to do it free to try and get your future custom, it only takes a couple of mins, most will just plug in to the charge / data port on the controller, select from the menu and adjust the speed etc. hope that helps.
Speed up the jet 3 power chair
What is the question??? The speed control buttons are on the keypad - left key to slow down, right button to speed up. Top speed about 4mph.
The chair has not been used in over a year now and we have been charging it for 24 hours now and it still has no charge. What should i do?
The batteries are too low for the charger to pick up. You need to replace the batteries This chair takes 2 U1 batteries. Hopr this helps
1helpful
Indeed, you need to find a repair shop. Try a google search for power chair repair, or ask your local hospital or if you can find one a power chair store. Most likely, you have a mechanical failure of the wiring, the battery themselves, or corrosion on the battery posts. Since the chair lights up when the charger is in, it is unlikely that the charger is broken. You may have a failure of the controller board, but that is also unlikely. And batteries do not usually suddenly fail completely; they typically fail slowly, losing the ability to completely charge.
I assume that you did not see a great deal of fluid leaking out of the battery container; you might look in the container and check to see if a battery is cracked or missing fluid.
Top Jet Health & Beauty Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
