A really annoying issue but your password is Your and only you are supposed to know it.
So I guess your only choice is to do a Factory Reset of your Coby tablet:
There may be mfr. updates for your tablet. Go to Settings/About Device/Software Updates to check for any updates. You have to be connected to wifi to do the update.
There are also alternate ROM distributions that can be used to give your tablet better functionality if it is limited. One such I have used is Uberoid. See UberoidTool Installing Uberoid was never this easy DOWNLOAD
Go to the Home page of this site and read through the discussion forum for your particular 'flavor' of tablet. One caution - if you don't have access to a copy of your current tablet ROM, you could end up 'bricking' the tablet by going this route. All of these alternate distributions use the SD card external memory slot to make their changes.
you can try here and no that I don't know this site owner and cannot vouch for any software there. Suggest you download to desktop and scan with you AV before you install. Solvusoft Microsoft Gold Certified Company
Steps on how to do the restart. -You have to turn off the system. -Then press and hold the power button until you will see a message that will popup in a window that saying "Device Options"Appears on the screen. -Then select the power off again then you can see it again.You can be able to check that it first. -Then just select okay And while holding down the -Back -Button -Then Press and hold the power button. -Until you see the Coby`s Logo -Then wait until it change to Android Logo. - Then press the Back button.And Then the system menu will appear in the screen. -And then choose the wipe data/factory reset. >Home >Menu Buttons >Press the back,the button once you select the wipe data/factory reset then just click option. Then the confirmation that you will see in the screen Is a "yes" "Option". Then Choose "yes"-delete all user data,option by using the "Home"and "Menu"buttons. Then it will perform the factory data reset. -wait until it done. -Then once your done the main system menu has to appear in the screen. -And then reboot the system. -Then you have to press the back button to reboot the system. -The system will reboot the initial factory data setting. -All the user data will be lost. -Then Give the reboot,at least for 5 minutes. -Then Do not assume the unit has frozen.
I am having the same problem with the mid7120. I bought two for my boys for Xmas. The appslib worked the day before Christmas. On Christmas day, I noticed their site was under maintenance. Now it says my device is not compatible on one and says to reset the date to June 20,2010 on the other.
go to appslib.com on the tablet and download update will work after that... as you need to update the appslib store app. It will ask you to overwrite file say yes....
