Canon PIXMA MP150 All-In-One InkJet Printer Logo
A
Anonymous Posted on Jul 14, 2014
How do I print from wirelesson my mg3150 - Canon PIXMA MP150 All-In-One InkJet Printer
1helpful
Unable to feed paper
MAKE SHOER THAT THERE IS NO SMOL BITS OF PAPER ARE STUCK IN THE FEEDER
1helpful
I have a fault with my lack ink.
hi, you need to elucidate much more. make and model of the printer, what is the problem exactly. please add more detail and repost the query
My printer is printing blurred letters on documents. how can I fix this. I have tried cleaning the ink cartridges but problem persists
If this isn't a driver issue I'd check to be sure the print head and ink cartridges are secure and not loose. Also check the drive belt on the head to be sure it's not slipping or broken.
Used it yesterday.Will not turn on today?
Have you checked any fuses in the plug top if applicable?
I am trying to print chords and lyrics ,but only the chords print not the wortds.can any one help?
I think this problem is not related to your printer but rather the software you are trying to print from.
I think it could be printer related only if you see jagged lines, meaning you have to clean the printhead.
Please be more specific about what program do you use to open those music sheets and print from? What computer and operating system do you have?
Canon Pixma MG3150 not printing or lifting paper from the input tray?
Please check the cartridges.Re install the cartridges properly and try.
if ink is dried refill the ink.some times will happen to new printers also.if waranty is there cary to nearest service point.
2helpful
Disable cartridge monitor Canon MG3150
try tthis
Press and hold the Stop/Reset button until the error clears.
If your printer doesn't have a Stop/Resume button, use the Cancel button. Hold the button - until the Alarm LED stops flashing,
or until the error message disappears. This takes 6-7 seconds.
Note: You will have to repeat the whole process with every cartridge that indicates empty (in the ink monitor).
Good Luck
Thanks
Printer does not seem to recogonize wirelesson computer.
if your pc have a wireless adapter consider reconfiguring it with the write parameters,
make sure the printer's wireless ability is okay
old marine
old marine
ZJ Limited
ZJ Limited
