Transcend 8Gb Jetflash 300 Usb Flash Drive Compact Design Logo
A
Anonymous Posted on Jul 14, 2014
Pendrive write protection unable to remove
Unable to read or format
adilnaq
Level 2:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 81 Answers
  • Posted on Jul 21, 2014
adilnaq
Expert
Level 2:
New Friend:
Night Owl:
Answers
81
Questions
Helped
12031
Points
153
Download Active kill disk from following link.
http://software.lsoft.net/KillDiskSuiteFree-Setup.exe
this will erase all data and protection files
1 Related Answer
Anonymous
  • Posted on Jul 22, 2013
SOURCE: i cannot format my 16 gb pendrive is show unable
G drive not read,not open , not formeting
25helpful
2answers
My pendrive is write protected how to format it ,it says that the disk is write protected and i can read the content in it but cant delete the contents what should i do to remove the problem
my pendrive is write protected how to format it ,it says that the disk is write protected and i can read the content in it but cant delete the contents what should i do to remove the problem--ATUL
1helpful
3answers
I removed my pendrive without safe remove and its next ady onwards i am not able to detect my pendrive can anybody suggest some remedy??
Assuming that you are using windows, go to drive management and see if the pendrive is detected.
If so, right-click on it and format it.
Or look for the HP USB Disk Storage Format Tool and use it.
Ajay Marya
Your pendrive is infected with Autorun.inf virus
to remove this virus install malwarebytes (It is antimalware software)and scan your whole computer as well as your pendrive when you scaning finish remove all threats
IF the above method is not work
Try to format in other operating system like windows vista or in windows 7 because in vista and 7 you can force format your pendrive
1helpful
Unable to format the cruser pendrive
Far too often these little things have an almost invisible read/write protect button on them. Look carefully, over the entire surface of the USB Flash Drive. You might have this switch turned to Write Protect, which means there is nothing you can do, until you turn it the other way, and allow the device to be written to.
Cheers!
-a.
4helpful
2answers
Windows was unable to complete the format
sir
u dont need to buy a new one. You can download file shredder from here . do following things :
  1. download and install file shredder
  2. shred all the files which are in pendrive(after shredding u will not be able to recover them)
  3. then try to format it .,
thankyou for using fixya
dont forget to rate the solution
have a nice day
Kingston Software For Kingston Pendrive
1helpful
Remove Write Protection
Click > Start > Run > type "CMD" Then
Type "CHKDSK" and type the letter of your Pendrive and "/F".
chkdsk Q: /F > press Enter
another example:
chkdsk D: /f
chkdsk E: /f
D or E is the letter or your pendrive.
Problem regarding the write protection of pendrive
go onto this website and download the formatting software: http://www.apacer.com/en/products/Handy_Steno_HA202_downloads.htm
I had the same problem with an old 64MB jump drive. I did some hunting around on HWA as well as Googling other forums. The general agreement seemed to be that the drive was simply dead. I tried changing all the permissions, attrib in CMD, and even logging into Linux as "root" (the equivilent of Microsoft's "Administrator") to no avail. I was able to back the files up to another drive, and they regained their permission settings, but from what I read, the drive was simply dead.
2answers
Write protection error on pendrive
Look for a small/tiny white switch on either the bottom or side of your pendrive and switch to the other side. there should be a tiny white switch on your pendrive...
Hope this help. dnt 4get to rate pls
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
k24674
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
