SOURCE: removing rubber door ring from Zanussi Aquacycle 800
getting it off is not the problem (just find the clip at the bottom of the seal and let it off and you can pull the seal out....getting it or a new one back on is the real problem...that I am looking for help on!
SOURCE: metal ring aroound rubber seal fell off.
Start with the spring at the bottom, work the retainer around until the seal starts to pull away from the washer. Now grip the loop that the spring attaches to on the side that isn't in place and open the retainer. Push the retainer in place and release the spring.
SOURCE: water leak between tank and main unit
Hi
If it is leaking on top of the machine and under the water tank, there is a seal that needs to be replaced. Lift off the water tank. There is a large gray doughnut cap that will pop off. Take a screw driver and slip it under the outside of the cap between the machines top and pry gently up and it will pop that side. Go to the other side and do the same. Set the cap aside and take you index finger and stick it in the center of the black gasket. Lift up and if the gasket comes out with it you need to replace it. Clean the inside of the receptacle before installing the new gasket.
Once you get the new gasket, slip it at a slight angle(flat side up), then take your finger nail and run it around the outside edge of the gasket. It will slip in, then push it down. Take the cover and snap it into place. Your good to go.
SOURCE: where can i find pump rebuild kit for simpson
There are so many sites like ebay etc..
The best one is :-
http://www.pressurewashersupplies.com/
Check and let me know, if doesn't find the kit.
Thanks for using "Fixya".
SOURCE: The rubber seal came off of the inside during the
The wire ring is the seal retaining spring, it fits in a groove at the rear of the door seal.
Double the seal back in the drum, and fit the spring around the seal at the rear of same, it fits inside a groove, it is difficult, so persist and be patient.
Please rate my solution.
Thanks.
Homebase sell packs of small plumbing O-rings for £1.79. One ring in this pack is of the size you need for the RAC HP132. Expensive but cheaper than a new pressure washer.
