How to reset this receiver,Onkyo TX-DS474 Receiver to factory default please?
SOURCE: Onkyo TX-DS474 Receiver shuts down after Standby mode.
It's going into a protect mode. The amp is probably shorted out. Disconnect the spkrs and turn it on. If it still shuts off, it's the amp, if not, it's the spkrs.
SOURCE: Onkyo - direct tv code for tx-ds 787
does anyone knows the code to control the onkyo TXDS 787 through the comcast.remote.?
SOURCE: i have a onkyo tx-sr506 receiver that turns it self off
This unit is in protect mode. This means that a problem was detected and the unit has shutdown to prevent further damage. The most common cause of this is failed output transistors. Plan on $20-$40 for parts for this repair.
Dan
SOURCE: Can I play my ipod through my Onkyo TX-SR600 receiver?
All you have to do is get a 3.5mm plug to two RCA plugs lead and plug the 3.5 Jack in the headphone socket of your ipod and the two RCA's into an aux imput and away you go. If you get one of the small docks, that will stop the battery running down, but you don't need one.
By the look of the picture on FixYa it looks the RCA's can go in the front socket under the volume control.
Testimonial: "Thanks so much. Great solution."
