Telstra Easytouch 4G phone
SOURCE: NOKIA N95 BLANK SCREEN
It must be a connection problem, to the LCD, or the light is not working.
Can only be sorted by looking at it really.
Back to Telstra I'm afraid. If it's new let them sort it out, if it's not try a reset take the sim card out first then input this code *#7780# (Best to use this code as a last resort)
Give it time to work.
SOURCE: My Telstra 'T106' is displaying
hey hi buddy.....
this problem is caused by viruses,which enters ur mobile when u transfer files from untrusted mobiles,they first attack ur memory card and corrupt files and eventually they delete the files also...
the best solution is to format the memory card and reinstall the mobile software from the nearest service centre.....
take care..thak u...
SOURCE: I have a telstra zte
hello,
There are different two ways of solving this nature of problem carefully off the phone for some time then on it after some time if the problem remain then make use of your USB cord to retain the power of the phone connected to the computer check on my computer (data) to copy your date in the phone
But on the numbers in the SIM remove the sim and then replace it another phone then you will be able to retrieve the date in the SIM .
Hope this help the problem?
thank you and thanks for using fixya.
SOURCE: how do you turn on
Normal
0
Try the following :- Enter 9999, and if that doesn't work try 1111 Remove the battery and note
the IMEI number on the label. Replace the battery and enter the last 4 digits
of the IMEI number. If none of these work, then
call your cell phone provider and request an unlock PIN number. You need to
provide information that you are the owner of the cell phone, the cell phone
number, and your address etc. This may work - Type #lock* then (END) It unlocks your phone, and displays
your password.
Unlock Cell Phones
Your cell phone may be locked to a particular cell phone provider and in this case it needs to be unlocked to use with a different cell phone service provider. To get the security code/restriction code to unlock the cell phone from the current cell phone provider so you can use the SIM card with a different phone provider, Please click on this link and follow my instructions :- http://www.fixya.com/support/r4049238-unlock_cell_phone If your phone provider does not help you then these WEB sites it provides security codes for a small price. http://www.mobileunlockstore.com/?gclid=CKDb2_y2558CFSlJagodxBkDHw http://www.mobileunlocksolutions.com/ http://www.superunlockcodes.com http://unlockcellphonecode.com/
of the IMEI number.
This may work -
Type #lock* then (END) It unlocks your phone, and displays your password.
