Canon PIXMA iP4000 InkJet Photo Printer Logo
A
Anonymous Posted on Jul 14, 2014
How can I scan on a Canon Pixma MX 532?
How do I scan with this printer, which is connected on a local network?
5 Related Answers
Anonymous
  • 5 Answers
  • Posted on Apr 29, 2008
SOURCE: i can't scan
hope this will help u about CANON MX310
http://canoncanada.custhelp.com/cgi-bin/canoncanada.cfg/php/enduser/std_alp.php?p_sid=Gk-ofu2j&p_accessibility=0&p_lva=&p_sp=&p_li=
Anonymous
  • Posted on Feb 01, 2009
SOURCE: canon pixma mx 300 won't send or receive fax
how do u fix the fax to fax and not go on auto redial
Anonymous
  • 1901 Answers
  • Posted on Mar 30, 2009
SOURCE: replacing cartridges in canon pixma mx 310
Go to this page:
MX310 Support
Click on the "Support & Service" tab. In the "Search Our Knowledgebase" block, type in replace ink and click "Search".
There should be a link at #1 dealing with installing ink cartridges. Click on the link and it will show with pictures and animation how to remove and install them.
Thanks for using Fixya.
Anonymous
  • Posted on Apr 15, 2010
SOURCE: Can't connect Canon Pixma MX310 to wireless network!
This printer does not have a network interface. There is no ip address for this printer. You must connect via usb.
Anonymous
  • 1138 Answers
  • Posted on Aug 04, 2010
SOURCE: canon pixma mx 320 error 5800
there are two ways you can remove the error message from your printer..
the first is to reset the printer and the second is to replace the waste ink absorber. If the reset thing did not work for your then you'll be spending money to replace the absorber.
How to reset? follow these steps
1. Turn off your printer
2. Press and hold the STOP/RESET button
3. Press and hold Power ON button
4. While holding the Power ON button, release the STOP/RESET button
5. While holding still the Power ON button, press twice the STOP/RESET button
6. Release the Power ON button
7. Wait until it display an "idle" message. It will take about a minute.
8. When "idle" appear, open the top cover to expose the cartridges.
9. Lift up the cover for cartridge holder and take out both the black and color cartridges
10. Return the cover of cartridge holder and turn off the printer
11. Return the top cover and turn on the printer again
12. After the printer initialize, return the cartridges.
Hope that solve the waste ink absorber in your printer..
Canon MX490 can not print, scan or trund off all the sudden
The canon MX490 Printer is not responding or printing due to various reasons.
• Check your canon Pixma MX490 connect with wireless and wired network
• Make sure canon Pixma printer connect with your computer or Mac device
• Update canon printer drivers
• Update outdated firmware
• Restart canon pixma printer
In case you have faced trouble to canon pixma Mx490 setup and installation printer, then read the following steps.
1helpful
2answers
Will the XL ink cartridges compatible with the PIXMA MX 490 printers? I read "yes" and "no" that the xl causes error messages.
The Canon Pixma MX490 can use the PG-245XL black and the CL-246XL cartridge.
The appropriate ink cartridges are listed in the specifications, the manual and the Supplies & Accessories information at the product support page: https://www.usa.canon.com/internet/portal/us/home/support/details/printers/support-inkjet-printer/mx-series/pixma-mx490 .
I hope this helps.
How to copy with my mx490
The wireless office printer /copier/scanner/ fax machine from the IJ Scan Utility Canon Pixma mx490 setup thanks to outstanding connectivity choices and the ability to put a lot more places with the printer than ever before? S 30% decrease in size compared to earlier variants of MX. With Google Cloud Print and AirPrint, you can print wirelessly from virtually anywhere around the office from your appropriate smartphone or tablet computer. It? Loaded with time-saving features, including a fully integrated automatic file feeder holding up to 20 sheets. And the optional XL ink cartridges also recommend you can print longer before your cartridges need to be changed. Using a 30 percent decrease in size relative to its predecessor, Canon Pixma mx490 setup Office All-in-Onejet Printer provides individual printing, scanning, copying, and fax capabilities in addition to wireless connectivity without sacrificing a big amount of your useful desk region.
2answers
How do i install canon pixma mx320 series printer?
hello,
Remove all the printer settings, and swich off the printer.And restart your system. install the drivers with MX 320 CD. Once it ask you to switch on your printer, please switch on then the printer it automatically it will detect and it will finish this.This is the normal installation procedure .
If you want more help from me please give me the details of the OS and error code and other's.
Tks
1helpful
I have a canon pixma MX850. I have connected to my network. Printing works fine. When I go to scan, the printer ask to which computer. I don't understand the question, much less the solution. Ho
Many machines allow network printing but not network scanning. I think you will find that the MX850 driver and MP Navigator software simply does not support network scanning. I suggest you query Canon directly.
Where can I get a network set up cable for canon mx 410 printer?
The network is wireless. The only cable that connects other than power is the USB cable for direct connection to a computer. That is the network setup cable. Any Type A to Type B USB cable can be used for the setup.
Canon Pixma MX850 won't scan - says 'set the pc to start scan'
Do you have more than one PC connected to the scanner? I have both a PC and a Mac connected to it, and I think my scanner is trying to connect to the Mac, which requires image capture software to be installed, rather than the PC. Don't know how to tell it to go to the PC, though...
4helpful
2answers
Canon pixma mx 300 won't send or receive fax
Dear friend,
it's very important to connect your MX 300 with the telephone line the right way! Please read once more the part "Preparing the machine for fax" in the chapter "Faxing" of the MX 300 User's Guide and mind the hint "Important: Do not connect the machine and external devices in parallel to the same telephone line using a splitter (A). The machine may not operate properly."
Greetings from Cologne (Germany) to the UK!
old marine
old marine
ZJ Limited
ZJ Limited
