My Amanda wall unit keeps freezing up. Cleaned filter and coils, please advise.
Thanks, Gilbert
If a AC unit starts to freeze up, then that is a sure sign that it is low on freon. A wall unit is harder to add freon to since those units generally do not have Shrader valves to purge or add freon. It is sort of like your refridgerator in that the freon is sealed in the factory and to add , a technician has to cut the evaporator tube and add a valve, then add freon, pinch the tube off and seal it once the correct pressure is adjusted.
I would say that somehow your unit has developed a leak, and will get worse.
see:http://real-estate-agents.com/tips/hvac/maintain-air-conditioner/
