Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Which wire harness is the rotor position sensor for WTW6600SW2?
2 Suggested Answers
6ya staff
SOURCE:
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: I have a wtw6600sw2 giving
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit.
This can be caused by several different problems.
Make sure that you are not overloading the washer. Overloading can cause this problem.
A toy or foreign object could be under the washer that is interfering with motor rotation.
With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily.
If not, you could an item caught between the spin basket and the tub.
You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board.
A failed RPS sensor or a failed control board could also cause this problem.
Thanks for using FixYa!
Posted on Feb 04, 2011
First seventh lights flashing
130. (10000010) Phase 1 to 6 Single Rotor Position Sensor Error
The Motor Controller has found an error in the pattern received from the Rotor
Position Sensor. Likely causes of this fault are a bad connection on the harness
between the Rotor Position Sensor and the Motor Controller, or a faulty Rotor
Position Sensor.
Primary Source: Wiring.
Action:
1) Check for corrosion on the edge connector of the Rotor Position Sensor and
the Motor Controller module connector.
2) Check the contacts on the rotor positional sensor end of the hall harness to
see if any have been damaged. (Each set of contacts in the socket has two
wipers. If the distance between these wipers varies between different
contacts, replace the rotor positional sensor harness).
Secondary Source: Rotor Position Sensor.
Action:
Check the Rotor Position Sensor with an R.P.S. tester. Replace if faulty.
Tertiary Source: Motor Controller module.
Action:
Replace Motor Controller module.
Aug 22, 2013 | Fisher and Paykel Washing Machines
Hi there i have a fisher and paykel washing machine that fills but part way it will stop then carry on then later the first and 7th lights will flash it also does it while it spins
That is error code 130
130.
(10000010) Phase 1 to 6 - Single Rotor Position
Sensor Error
The Motor Control Module has found an error in the pattern received
from the Rotor Position Sensor. Likely causes of this fault are a bad
connection on the harness between the Rotor Position Sensor and the
Motor Control Module, or a faulty Rotor Position Sensor.
Action: 1. Check for corrosion on the edge connector of
Control Module connector.
2. Check the contacts on the rotor positional
sensor end of the hall harness to see if any
the socket has two wipers. If the distance
different contacts, replace the rotor positional
sensor harness.)
Action: Check the Rotor Position Sensor with an R.P.S.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
Jan 01, 2013 | Fisher and Paykel WL26CW1 Top Load Washer
Fisher Paykell error - mw051-u
Your fault code is unknown,
Try these.
130. (10000010) Single Rotor Position Sensor Error
The Motor Control Module has found an error in the pattern received from the Rotor
Position Sensor. Likely causes of this fault are a bad connection on the harness between
the Rotor Position Sensor and the Motor Control Module, or a faulty Rotor Position Sensor.
Action: Check for corrosion on the RAST connector of the Rotor Position
Sensor and the Motor Control Module connector.
Action: Check the Rotor Position Sensor with an R.P.S. tester. Replace if
faulty.
Quaternary Source: Rotor
Action: Ensure the correct rotor for this phase of machine has been fitted
136. (10001000) Motor Stall
The Motor Control Module has been unable to start the motor. Possible causes of this fault
are: Faulty motor harness, faulty or jammed motor, seized bearings or seals, faulty Motor
Control Module, faulty Rotor Position Sensor or harness.
Action: Measure/check the motor harness, connectors and motor for
discontinuity. This can be done by taking a resistance measurement
between phases of the motor harness at the Motor Control Module
end. If an incorrect reading is obtained the reading should be taken
directly from the stator.
Secondary Source: Motor.
Action: 1) Check free rotation of the agitator and bowl by rotating by hand.
Bearings and seals may be seized.
2) Check the Rotor Position Sensor and associated harness for
water, mechanical damage or corrosion.
Action: If the primary and secondary checks pass inspection, then replace
the Motor Control Module.
Dec 17, 2012 | Fisher and Paykel Washing Machines
Fisher & paykel intuitive eco manual, bearing & seals need replacing
Error code 130 is Rotor position sensor fault.
130.(10000010) Phase 1 to 6 Single Rotor Position Sensor Error
sensor harness.)
Go to this site & select your model for parts view.
You will need Adobe reader to view PDF's
http://www.jordansmanuals.com/default.aspx?Brand=FP&Product=Washing
Oct 05, 2012 | Fisher and Paykel Washing Machines
I have a fault code on off off off off off on on
That is fault code 131
131. (10000011) Phase 1 to 6 - Repetitive Rotor Position
Sensor Error
This fault is similar to fault number 130 above but differs slightly in that
it is a continuous condition. See fault 130 for service procedure.
130. (10000010) Phase 1 to 6 - Single Rotor Position
Sensor Error
sensor harness.)
Sep 17, 2012 | Fisher and Paykel Washing Machines
What does Cold 130 mean?
Error code 130
130.
Sensor Error
sensor harness.)
Sep 02, 2012 | Fisher and Paykel GWL11 Top Load Washer
Fault code 130 appears on my fisher and paykel intuitive eco washing machine, do I require a technician to fix this?
Sensor Error
sensor harness.)
Aug 25, 2012 | Fisher and Paykel Washing Machines
Gw712
Fault code 130
Sensor Error
sensor harness.)
Feb 29, 2012 | Fisher Paykel EcoSmart GWL15
Intuitive ECO Model IW811 display error codes 240 and 130. what does this mean?
The fault codes 130 and 240 are pertaining to a Rotor Position Sensor problem. It is the part located wedged into the motor stator and it's sole function is the detection of motor functions particularly the rotor as the name suggests. The problem can be a simple loose wire harness or a damaged Rotor Position Sensor.
Unplug the machine. Tape the lid closed then lay the machine's front on a padded floor. Remove the single bolt holding the "plate-like" rotor to the shaft to access the Rotor Position Sensor. Once the rotor is off, check the contacts on the Rotor Position Sensor end of the wire harness to see if any have been damaged. Each set of contacts in the socket has two wipers. If the distance between these wipers varies between different contacts, replace the Rotor Position Sensor harness. Consider replacing the Rotor Position Sensor if no issue is found with the harness and the connectors.
Jul 18, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
I have a wtw6600sw2 giving a f-51 code. I replaced rps sensor and harness and control board. Still giving me f-51.Also there is nothing between the tub, tub turns freely.
Feb 03, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
204 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
