Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Logo
A
Anonymous Posted on Jul 13, 2014
Pull cord on weed eater won't engage - Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger
Richard Haynes
Level 3:
Master:
  • Poulan Master 673 Answers
  • Posted on Dec 07, 2017
Richard Haynes
Poulan Master
Level 3:
Master:
Answers
673
Questions
0
Helped
208112
Points
1403
If the pull cord does not turn the engine over, the starter pawls are probably not working properly.
4 Related Answers
Anonymous
  • 1498 Answers
  • Posted on Aug 15, 2010
SOURCE: I bought a weed eater gti25t at an auction. The
There are quite a few different types pull start engagement mechanisms out there. As such, you would think replacement parts would be more readily available at the larger chain stores that sell the bulk of small engine powered devices. Not so.
I'm lucky to have found an excellent local small engine repair shop that keeps a nice variety of parts in inventory. It's a Mom and Pop place called Mr and Mrs Chainsaw. You gotta love it.
I brought a weedeater in to get parts for a similar problem to yours. Keep in mind, I'm a tech, I do ALL my own repairs.
The cost of the fix in parts and labor to replace the grab ears on my Husquavarna was so ridiculously low that for the first time I let someone else work on my equipment.
Is your device worth fixing? Absolutely.
The repair you need is straight forward and intuitive. The cost will be your time finding the parts.
If you can find your own Mr. Chainsaw? Doubly so.
Best regards
Mike
Anonymous
  • Posted on Sep 24, 2010
SOURCE: Weed Eater PE550 - How do you change the spring
Lay the unit on it's side, carborater down. Removed the 3 screws holding hold the gear assembly housing. Hold the clutch assembly inside a cloth with a wrench and remove the nut. Left from the starter cup as a stack and set aside. There is a starter retaining ring on the shaft. Pull this with a long nose plyers. If it spings free, it is easy to loose. Then left out the starter pully. The starter spring is under the pully. Remove it with a sharp pointed tool. A broken one is crusted in rust and will be snapped off inside the coil.
Anonymous
  • 97 Answers
  • Posted on Sep 02, 2011
SOURCE: My Poulan Pro 150E pull cord will not engage to
Sounds like the starter dogs are broken. They are little plastic teeth that engage to turn the engine when you pull the cord. You'll need to replace the whole starter assembly to fix this.
Anonymous
  • 316 Answers
  • Posted on Feb 19, 2012
SOURCE: weed eater made a noise then just quit working, pull cord wont engage
hello sir, Please provide the following information so that your issue may be diagnosed properly,what is it? brand name,complete model number The problem, What is happening with what? When it is happening? Are there times it does not happen? Did it just start happening? Did it ever work ? Did any seemingly unrelated event coincide with whatever it is not working? need the model number and brand name, if you need a manual i need the brand name and model number,if it is a riding mower the model number is under the seat.a snow blower the model number is on the rear of the machine, let me know,thank you. ~~ i need to know this before i can give you a answer,,
How do i fix a cord not going back in on a craftsman weed eater/blower combo 32cc
The one way clutch could be broken or jammed. Take off the starter for a closer look.
1helpful
My weed eater (toro), won't let me pull the cord at all. This weed eater doesn't take oil I don't think.
All internal combustion engines use oil of some description. I take it this is a 2 cycle engine and you have not added oil to the gas. If this is the case the engine is locked up, and must be replaced. Sorry.
Weed eater made a noise then just quit working, pull cord wont engage
3helpful
My Poulan Pro 150E pull cord will not engage to start the weed eater. The rope comes out adn retracts back with no problem, but there is no pressure on the clutch to cause the motor to start. There is...
4helpful
Pull Cord won't pull on model TB525CS
Hi try this web site its called pats small engines shows exploded view
1helpful
Top Poulan Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Poulan Garden Expert? Answer questions, earn points and help others
