Good Afternoon Friend, this is Z. Thank you for your inquiry!
Normally error code E64 is an indication that the heater circuit is in the open position. This is not a simple DIY job; I would highly recommend consulting a professional to move forward accurately. The certified technician will need to check the heater coils and connections for open circuits. Depending on the diagnosis the heater or wiring may need replacing.
Heating element replaced worked fine for 2 weeks and now showing error code e64 again
Hi gordsxbstn34 - Typically error code E64 indicates that the unit has detected that the heater circuit is open. Contact a professional to move forward accurately to check the heater coils and connections for open circuits. Depending on the diagnoses heater might need replacing and/or wiring
