Can u help me out? my IMEI is 357981/03/563155/5
SOURCE: forgot security code
security no is 12345 as standard
If you have changed this and forgoten what you changed it to then you will need to take it to a tech to have it reset to the default code
SOURCE: plz help me unlock my security code..Nokia 6288
hi, i can give you the master code but you need to read this first ok.
1. the master code wont work if you have entered 5 wrong codes as the phone will be hard locked and can only be unlocked using flash lead and unlocking software.
2 the code only works if the phone asks for security code when first swtched on.
If you have not entered 5 wrong codes then this master code will reset the security code and remove it unless you want to put another security code back on the phone.
enter this code when asked for security code ok 4365426660.
This code will only work with your imei number as every single phone has a unique master code based on the imei number ok so double check the imei number before trying the code.
Any problems just give me a shout back ok.
SOURCE: forgot N95 8GB security code
hi
i ve nokia N95 8 GB I FORGET MY PHONE LOCK CODE ,MY IME NO IS 356842029513038 PLZ HELP ME HOW TO I SOLVE MY PROBLEM
