Www.docyue.com/nupdf/maytag-calypso-washer-error-codes.pdf
I already have the manual... Thanks
Maybe I should explain it better... I am having a problem with my Cabrio top load. It starts the cycle on wash but when it gets to the drain and spin part and code LD comes up? Any idea what may be wrong? If I hit the pause button, lift the whole top of the washer up, and then hit the start button, the cycle will continue normally. Once it is drained down and goes into the rinse cycle, I put the cover back down, the machine will do the same thing again when it gets to the drain and spin cycle. I once again have to hold the cover up for the last 10 minutes of the cycle to get it to drain and spin out properly.
There is also some water leaking at the bottom of the washer as well
If you wish to fix it yourself, obtain a service from the company and go from there. Noone can dianose your problem with out training tehy receive from the repair /service manuals.
