Cameras Logo
A
Anonymous Posted on Jul 13, 2014
Cannot get a full screen view when trying to take a photo. Just a line that shows what I want to photo and the rest of the area is dark
5 Related Answers
Anonymous
  • 216 Answers
  • Posted on Sep 22, 2006
SOURCE: reddish vertical lines on LCD & view finder
There is a CCD service advisory for the F717. They will repair it free of charge. Go here for more details: http://www.imaging-resource.com/badccds.html
t00nz
CameraR
  • 4738 Answers
  • Posted on Jan 10, 2008
SOURCE: no picture on view screen of my ixus 400 cannon
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
t00nz
CameraR
  • 4738 Answers
  • Posted on Apr 21, 2008
SOURCE: cannot take pictures
Sounds like you might be in luck. These symptoms sound very much like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
zohail
Shoaib Rais
  • 1223 Answers
  • Posted on Mar 27, 2009
SOURCE: LCD screen is black with horizont lines when trying to take photo
U ARE LUCKY !
it is CCD PROBLEM
thousands facing the same see the link but the best part is u can get it repaired free of Cost bcoz it is a manufacturing fault
see the link
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT1&news_id=161
Pls rate me FIXYA for help
Texas Appliance And TV Services
  • 57 Answers
  • Posted on May 09, 2010
SOURCE: When i take photo on any of the settings the photo
Your Camera CCD is bad, need to replaced CCD
What is a small dark area appears on viewfinder and photos?
is it only the view finder or does it appear on the photo as well because if it the view finder then it is the screen and if it is on the photo as well then its most likely the lense and once you have deterined this then you can know if it is just dirty or if the screen needs replacing
Sony cybershot t300 lcd screen remains dark when switched on
Your camera must be experiencing these symptoms due to a faulty CCD, and not due to other problems. If the problem is due to your dropping the camera, you might be out of luck.
If you have not dropped your camera and still facing this problem, then contact service people to replace the CCD imager in your camera .
Hope this helps .
Shane
The image on the TV has sort of condensed and disappeared. Now there is a bright line across the middle of the screen and a sliver of (about an inch) of image above that line. The rest of the screen is...
You have a vertical output IC that needs repaired. You may need to only resolder the vertical output IC. If then you do resolder, you will need to check and replace any capacitor in the immediate area of the vertical IC. A weak or bad capacitor will heat up the IC, and create rings on the pins under the IC. Also check the solder grounds on any resistor and diode that are immediately near this IC. This will bring your TV back to full view. Thanks for asking and show a few hands of support!
Poor quality of viewing Photos, Online TV and Videos
change to screen resolution to 32 bit.
to do this, right click on any empty area on your screen, select setting and change the screen resolution, from 256 to 32.
Canon powershot a75
1. i am not able to view the background from LCD.
2. i tried switch DISP button on and off.
3.Rest all the functions are working fine in camera.
4.LCD is on with Blurr Screen.only thing background and captured photos cannot be viewed.
3answers
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Canon EOS Rebel XTi Somehow have changed my photo viewing mode from a full screen to much smaller photo with a "graph" beside and data beneath. How do I change it back to a full screen view of...
With the camera in Playback mode (reviewing pictures you have already taken), press the DISP button until the LCD shows what you want -- no information, basic information, or full shooting information.
2answers
Photo showing only in Full Screen Reading - want it gone!
cut that picture and paste it into a blank document then reduce the size then reinsert the photo in the document
1helpful
2answers
The LCD screen is hard to see. What should I do?
If the LCD screen is too bright or too dark, adjust the LCD Brightness setting in the Setup Menu. If you are shooting photos outdoors in bright light, move the joystick to the icon showing the sun over shaowed area to turn on Outdoor mode and make the LCD screen easier to see in bright light.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
