One solution would be to go to the manufacturers site and make sure you have the latest firmware update. If your floppy doesn't work, then apparently you are aware of this, and your floppy drive is defective, correct? Moving on then, you can also use a flash drive which are pretty inexpensive right now. It will plug right into your USB port. Another means of getting it into your laptop is to send it to yourself email. Now, if you cannot get passed the need for this to on floppy, then you simply need to get a new floppy drive.
Now, assuming you do indeed have the latest firmware loaded, the problem is the fact of this drive being a bit inferior. It is a dust magnet. Installed in a laptop, it picks up any and every bit of dust that so happens to venture thru.
Solution :. I took the DVD/CD-Rom out, removed the alluminium plate that is held on with 3 little screws and inspected it. I found alittle dust on the DIVERTER(?) mirror/lens. I blew if off, cleaned the primary lens. I reassembled it, put it back in the laptop and now it works fine on ALL CD's. BE VERY CAREFUL WHEN CLEANING THE PRIMARY LENS. BE VERY GENTLE. If this fixes your problem and if you can Please pass this on. It saved me ALOT of money. Almost forgot, the ERROR Message that I would get, before I fixed it was "WINDOWS CANNOT READ FROM DISK.THE DISK MIGHT BE CORRUPTED OR IT COULD BE USING A FORMAT THAT IS NOT COMPATABLE WITH WINDOWS. I hope this fixed your problem.
