I replaced the replaced the carburetor so now the blower is getting gas into the cylinder, and it has plenty of spark, so the flywheel is now the only possible reason for the blower not starting. I would like to know WHERE the flywheel is located on my PB251 blower? Which side and what needs to be removed to get to it? I have a bad feeling that the flywheel key is sheered, and the flywheel needs to be replaced, since this seems to be common on this model Echo blower.
SOURCE: cant get fuel into cylinder will not fire
Carburetor may need rebuild, sound like diaphragm are not pumping fuel.
I would get a compression test on the cylinder to see if it is at 100 psi. This is the compression the cylinder needs to be at to run. You may pay a few dollars to get a shop to do this but it will tell you if it is worth fixing before you spend alot of money.
SOURCE: Hello, what is the gap
a bussiness card thickness, slide it between flywheel and coil, the rotate till magnets catches coil the tighten up
SOURCE: I have a PB251 Echo blower that won't start. I
I suggest cleaning the carburetor and replacing the diaphrams. The diaphrams come with a rebuild kit that has a lot of unused parts.
