Help... I have a 92 350 chevy truck that will not start. I have replace the ECM, coil, ignition mod., the fuel pump relay and the fuel pump. When i turn th Ignition switch on th fuel pump doesnt come on....
You said you jumped the wires for the pump? Was that at the pump relay?
If you have a voltmeter or test light, keep the jumper wire in place and check for voltage at the fuel tank connector. The pump wire will be gray. With relay out and jumpered there, you should have battery voltage at the fuel tank connector. The key doesn't even have to be on, cause the relay has voltage to it at all times. If you jumpered it right (terminals 87 and 30 on the relay), and no voltage at the tank connector, you have a broken fuel wire somewhere between the relay and the fuel tank.
If you do have voltage at the tank, but the pump still won't work, only two possibilities, a bad pump or the ground for the pump is lost. Check the pump ground first.
