These types of severe cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", "print cartridge(s) problem" etc.) typically indicates the internal micro-electronics of the HP #21 / 22 cartridge are damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); it is also possible to bypass the error (temporarily) on OJ models For reference/guidance, below are the procedures for printers which use HP 901 cartridge which are similar (I will soon upload procedures for the OJ 5600 series); Inkjet411 youtube videos: HP Officejet J4500 J4600 4500 Printer Error Messages -HP 901 & 901XL Cartridges http://www.youtube.com/watch?v=RivHgvWCkJ8 HP 901 & 901XL Ink Cartridge Alerts - Low Ink Warnings: http://www.youtube.com/watch?v=hzLM5mlkTt4 HP Officejet J4500 J4600 4500 Printers Tap 41 Diagnostics - HP 901 Incompatible Print Cartridges: http://www.youtube.com/watch?v=S6uATgXxQlE
HP Officejet J4500 J4600 4500 Cartridge Error Bypass - HP 901 Cartridge Errors: http://www.youtube.com/watch?v=I4-m_RLdRE4
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab64
Put your old cart in then goto "settings-clean cartridge once done take old one out replace with new.
SOURCE: "Cartridge Error: Cart. on left is not intended for this printer"
hi,
lost, Scanner does not work, Connection problem etc. For find all these software solution
just click here....
djiu9o15
