SOURCE: Kenmore 22422 Washer will not spin
You never mentioned a problem other than getting the console off. Describe your symptoms, so I can give you better advice.
SOURCE: kenmore 22422 not draining or spining
If it is same as in photo (Frigidaire built) your drain pump is probably blocked/jammed. You have small children?? Kids socks seem to find their way to the pump often.....
Misti, usually no spin, no drain is a broken lid switch. part #3949238. See if the switch is busted off from the screws. Catriver
SOURCE: I have a kenmore 22422
IS IT SPINNING FULL SPEED AND IS WATER COMEPLETELY OUT OF TUB HOW OLD IS THIS WASHER IF YOU WRITE BACK PUT ATT KENNY
SOURCE: Our Kenmore top load model 22422 started having
The double shaft motor does double duty. One direction for wash and another direction for spin. In wash mode the water stays put in the tub because the pump is running backwards. In spin mode the motors turns in opposite direction. This pumps the water out and spins the clothes dry. From what you have described the drive coupler is toast.
This video shows how to swap the drive couple out:
More HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Take a look at this tip I wrote on the no agitate or spin condition of your washer.
