Indesit W 123 Front Load Washer Logo
A
Anonymous Posted on Jul 12, 2014
Remove Miele W3740 front plinth - Indesit W 123 Front Load Washer
Miele W3740 Drum shaft spider - 3 arm - broken
It looks like it might be a UK Model. They are normally cast aluminium. You may be able to get it welded.. There are some parts suppliers in the links.
https://www.google.com/search?q=miele+w3740+drum+spider+replacement
https://www.google.com/search?q=miele+w3740+parts
AEG FFE62620PM dishwasher had error code i30 for second time in 2 months. How do I remove the plinth?
To remove the plinth on your AEG FFE62620PM dishwasher, please follow these steps:
  1. Turn off the power supply to the dishwasher by unplugging it or turning off the circuit breaker.
  2. Open the dishwasher door and locate the two screws on the bottom of the plinth. These screws are located on either side of the dishwasher and are usually covered by plastic caps.
  3. Remove the plastic caps and use a screwdriver to unscrew the screws.
  4. Pull the plinth away from the dishwasher to remove it. It may be helpful to have someone hold the dishwasher steady while you do this.
  5. Once the plinth is removed, you should be able to access the base of the dishwasher and any components located there.
  6. If you need to reinstall the plinth, simply reverse the above steps.
1helpful
2answers
How do I fix a F53 fault on a Miele W3740 Washing Machine
First, unplug the washer for minutes then plug in and see if it solve the problem, if not then check the carbon brushes on the motor. These are a part which is expected to wear and when they do the motor cannot rotate the drum, which means the speed sensor thinks something is wrong and throws the error.good luck. Fixing an F53 on Miele washing machine
How do you open the front panel to check the brushes
  • Open the door
  • Pull out the mains plug
  • Remove the metal ring around the door opening seal (apply pointed pliers to stretch the spring beneath the door opening)
  • Push back the seal from the front panel
  • Loosen the two door opener screws
  • Remove the plinth
  • Remove the two outer upper screws behind the plinth
  • Remove the bolt right underneath the door opening while supporting the front panel
  • Gently lower the front panel and take it away
If the brushes are all right, then probably the electronic is defective.
Check for our repair service at www.youfixit.eu.
Cannot open door
The door interlock may not have engaged properly! This has happened to me and I use my knee and bang it against the door near the catch and once the lock is engaged the door open button will work. If not you'll need to remove the rectangular access panel above the plinth and get a flat head screwdriver in the slots to open the door.
3helpful
I just got a ntc Temperature Sensor for a W1213 Washer and was wondering how easy it is to change??
Easy.
Make sure there's no water in the drum.
Important! Switch off and remove plug from electricity supply!
Remove front base plinth (pulls off use a plastic lever if necessary - one inside soap dispenser drawer). Remove front panel of machine (torx screws at bottom, torx screw under drum. Slacken wire around door seal and remove (hook it with a smallish screwdriver. Do not damage seal. they are ridiculously expensive).
Unclip seal from front panel. Pull front panel out from the bottom, then down. Reach around the now detached front panel and unclip door lock wiring). Put panel somewhere it won't fall over.
Locate element underneath drum at the front - oval rubber with connections to it.
Temperature sensor is in the middle of the element. Unclip the plug from the back of the sensor. Gently but firmly pull the sensor out toward you. It's just a friction fit in the rubber. you can use narrow pliers but don't crush the socket of the sensor. If you want to test it, put a multimeter set to ohms on it. Resistance will vary under say a hot or cold tap/faucet.
New temperature sensor will push fit into old hole - moisten case first to make it easier with a tiny bit of washing up liquid (or spit!). You might want to test it first as above.
Reconnect wires, lock harness, front panel, attach door seal, attach door seal retaining wire, screws, base plinth.
Congratulate yourself on saving shed loads of cash.
1helpful
23 in. Novotronic G841 Built-In Dishwasher: the door on my miele G481 built in dishwasher won'...
hi,
you need to adjust the door tension springs which is by a screw each side of the hinges on the plinth of the unit at the front. There is a symbol of a spring to show you which screws to release. do them evenly and the door will not spring up,
Miele transit rods stuck
My husband was able to pull it out .
Top Indesit Washing Machines Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Sean Wright
Sean Wright
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
