Posted on Jun 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Trying to connect wireless, but computer does not see printer. I have cliced on wireless lan setting, then I click on wps setting, but after that do not know if it push button method or pin method, If I click on push button method, it then says commenct to a wireless lan access point supportint the WPS push button method. Nothing happens after that. What do I do. I have the PIXMA MP620
Anonymous
Level 2:
  • Expert 94 Answers
  • Posted on Jun 29, 2009
Anonymous
Expert
Level 2:
Answers
94
Questions
Helped
32411
Points
273
You try to uninstall the driver and restart the pc against , then try to install the proper software again. it work properly
1helpful
2answers
I am trying to connect my canon pixma 452 printer to my samsung tablet. Where is the WPS button ?
WPS Connection Method Before we start, there are some conditions that must be met in order to use the WPS push button method:
  • The access point must have a physical WPS push button available. Please check with your device's user guide for details. If the WPS push button is not available please use the instructions on the Standard Connection Method tab.
  • Your network must be using the WPA (Wi-Fi Protected Access) or WPA2 security protocol. Most WPS enabled access points use this protocol.
Step 1 1. Press the [Setup] button (A) on the printer.
Step 2
1. Select [Wireless LAN setup] and press the [OK] button.
The blue Wi-Fi lamp (A), will light up when the wireless connection is enabled.
The printer will now automatically search for access points supporting the WPS feature
Step 3
The display on printer should be as shown below:
(The message will read: "Press WPS button about 5 sec. and press [OK] on the device)"
1. Press and hold the [WPS] button on the access point.
For exact instructions on starting WPS on your access point, please refer to its user guide.
2. Press the [OK] button on the printer within 2 minutes.
The blue Wi-Fi lamp on the printer flashes while searching for or connecting to the access point.
Once connected, the following screen will appear. Press the [OK] button.
If another screen appears, please refer to "troubleshooting" in the user guide.
This concludes the WPS setup procedure.
Please now proceed by installing the software to make the most out of your PIXMA MX474.
  1. If you do not have the installation CD that came with your product, please download the manuals and software.
If the WPS wireless setup is still failing after following this guide, please Contact us for further assistance. 1 888 224 4280
Where do I find the WPS PIN on my canon mg3220 printer. I need it for installation on a new router
I believe that Justus answer is incorrect and looks to be AI Produced. The SSID WPS PIN number is on the Router not on the printer. You tell the router to search for the printer, and you tell the printer to look for the Router. When they find each other, the Printer will ask you to enter the SSID and WPS Password that is on the Router. This is the way I did my Canon MG7120 to a Bell Home Hub Router. The process is the same setting up my iPhones for WiFi.
It is shown here
https://support.usa.canon.com/kb/index?page=content&id=ART137489
1helpful
Where is wps button?
About 49,500 results (0.39 seconds) Search Results
    What is WPS and how do I use it to set up the printer on the ...
    https://support.usa.canon.com/kb/index?page=content&id...
    Jan 15, 2016 - Use the , , and keys to select WLAN setup , then press the OK button. The printer will search for Access Points / Routers. If a WPS-compatible ...
    where is the WPS button? - Canon Community
    community.usa.canon.com/t5/Printer...Support/...WPS-button/td.../8893
    Dec 27, 2012 - Hello dmlarsen. The WPS button is not on the printer. This button would be located on your router itself. If your router does not have a clearly ...
    How to perform the wireless LAN setup using WPS connection
    support-th.canon-asia.com/contents/TH/EN/8200685600.html
    Dec 10, 2009 - Press and hold the WPS button on the access point (for about 5 ... If the Printer Connection screen appears instead of the screen above, the ... images for Printers & Copiers Where is wps button
2answers
Canon pixma mx712 code B200 , what's the solution ?
Try the following:
1. Open the cover of the printer.
2. Remove all ink tanks from the printer.
3. Lift up the gray locking lever on the side of the ink tank holder.
4. Gently remove the print head from the carriage unit.
5. Place the print head back in and lock the lever down.
6. Place all of the ink tanks back in the printer.
7. Close the cover and turn the printer off.
8. Unplug the power from the printer. Leave the power unplugged for about 5-10 minutes.
1helpful
Can't connect to wireless network from canon mp499
Steps to Connect Canon MP499 to Wireless Network:
1. Check Wireless Network Settings:
Make sure your wireless network is operational and that you have the correct network name (SSID) and password.
Ensure that your Canon MP499 is within the range of your wireless router.
2. Printer Display:
On the printer's control panel, navigate to the setup menu. Look for a wireless setup option.
3. Run the Wireless Setup Wizard:
Initiate the wireless setup process on the printer. This often involves navigating to the "Wireless LAN Setup" or a similar option.
Select the option to connect to your wireless network.
4. Enter Wi-Fi Credentials:
When prompted, enter your Wi-Fi network name (SSID) and password. Ensure that you enter the correct information.
5. WPS (Wi-Fi Protected Setup):
If your router supports WPS, you can use this method for easy connection.
Press the WPS button on your router.
On the printer, select the WPS option and follow the on-screen instructions.
Greetings,
Antonios
2answers
Can not conect to wifi
the canon MP170 is not a wifi printer, you need to connect it to a computer via usb, if you have have a second computer on your network you may "share" the printer across the network.this will allow you to print wirelessly to the printer via the connected PC.
I'm trying to connect my wireless HP DeskJet 3050 printer with my computer. In the set up it said to Press the WPS button on the router. The product automatically finds the wireless network and configures...
Click Start, All Programs, HP, HP Deskjet, Connect a new printer. Choose Network Printer, then connect the USB. It will transfer the wireless settings. Unplug USB. Viola! Wireless works.
k24674
ADMIN Andrew
ADMIN Andrew
