SOURCE: Electrolux Pronto 2-in-1: Looking for a part
There is no replacement for the dust container in these units. You would have to get an entire handvac which costs more then a full unit.
SOURCE: can the battery be replaced?
No but there was a recall on the battries, so try calling electrolux usa and they should replace it for free.
SOURCE: Electrolux 2-in-1 Pronto does not hold charge, I
The battery replacement for the PRONTO is not a consumer level maintenance procedure.
However, I just replaced the 4 original EMX1600sS batteries by anotther
model with the same specs and my PRONTO is working fine now. The battery
model is
Tenergy 2/3A Size Rechargeable Battery 1.2V 1600mAh NiMH W/ Tabs
Those are a little smaller than the originals but with the same capacity of 1600mAh and can be easily found in the web.
There are other similar models available that could be used but have in
mind the limitations for the dimensions and capacity in mAh.
The dimensions of the original cylindrical batteries are aprox. 33 mm (1 1/4") X 22mm (7/8").
Anything under those specs should work.
Good luck.
SOURCE: i need to ,now what
for this problem I would get in touch with electolux directly and they will tell you which and they will also have access to a new one if you need it..There are electrolux authorized dealers all over Canada and the USA so depending on where you are just pick up the phone book and goto the yellow pages under vacuums and that will give you the info that you need. Thanks for choosing Fixya.com
