Question about Magic Chef 9122 Gas Single Oven
How do I ignite the oven on a Chef Benchline 540?
2 Suggested Answers
Anonymous
SOURCE:
Anonymous
SOURCE: How do I ignite the oven on a Chef Benchline 540?
The ignition for the griller on our Benchline 540 isn't working properly - it takes about 10 tries then explodes. Any ideas?
Posted on Jul 04, 2010
How do i check the hot surface igniter on a magic chef oven
If the igniter is glowing orange or has a bright spot and the rest is dull then replace it. If it is a bright yellow then it should be fine. If you get no glow at all you can check it for continuity. If there is no continuity then it is bad.
Oct 11, 2014 | Magic Chef Ovens
Magic chef oven with uniburners oven will not light. igniter gets red hot but seems like no gas coming at all. burners on top work fine.
Since the bake burner does glow yet no flame that means that the igniter is weak and should replaced...the way the igniter works is that it comes on and get very hot where upon getting hot it draws a certain amount of amperage which will allow the gas valve to open resulting in a flame. The igniter is indeed coming on yet its not getting hot enough to draw the proper amp drqaw to open the gas valve...by replacing it with a new fresh igniter it will draw the correct amprage and let the gas flow.
GENE
Oct 02, 2011 | Magic Chef Ovens
Oven inconsistant heating up to tempeture how much is an igniter for Magic Chef gas oven
Hello, Thank You for using FixYa. I will be helping you today.You can use ignitor #12400035 Its about $50 but search on google to find the best price.
Thank You and please rate my answer if it was helpful..
Jun 24, 2011 | Magic Chef 9122 Gas Single Oven
Magic Chef: 9122: ingniter works and turns oven on BUT after a few minutes it turns itself off and later it turns itself on again and so on. Igniter problem or thermostat problem?????? Thank you for your...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 11, 2010 | Magic Chef 9122 Gas Single Oven
The 4 burners work, but the oven does not work on my Model 3187 VUV magic Chef.
heatman101
Oct 12, 2010 | Magic Chef 9112 Gas Double Oven
Mar 07, 2010 | Magic Chef 9122 Gas Single Oven
Oven stopped working
No, that is a top burner valve. Most likely the igniter is bad, part # 12400035. The only way to test it is with an ammeter; it must draw a minimum of 3.3 amps to cause the valve to open. Oven valve part # 7501P133-60. These go bad as well, but not nearly as often. If you are going to take a risk, try the igniter first. Available for $40 at www.timerking.com and elsewhere. Hope this helps!
Jan 28, 2009 | Magic Chef Ovens
Magic chefa313-230lw gas ignitio
hi .thanks for the question . A very common problem with gas ovens replace the igniter thanks the appliance doc
Sep 29, 2008 | Magic Chef 9512 Electric Single Oven
Stoves oven
check for 110 volts at the igniter if you do have it then change the igniter... whirlpoolpartssurplus.com
May 19, 2008 | Magic Chef 9122 Gas Single Oven
Magic Chef 9122 Gas Single Oven Logo
54 people viewed this question
Top Magic Chef Ovens Experts
Thomas F. Schneider
MARLON KELLER
Are you a Magic Chef Oven Expert? Answer questions, earn points and help others
