Brother DCPJ125 All-In-One Inkjet Printer Logo
J
JOSE SIDAMON RAFINAN Posted on Jul 12, 2014
My printer brother DCP-J125 "machine error 31"
4 Related Answers
Anonymous
  • Posted on Aug 18, 2011
SOURCE: i have dcp-j125 printer there
Brother pirnter j125 in 48 erre
Anonymous
  • Posted on Sep 30, 2011
SOURCE: Just bought Brother Printer dcp-j125,After
Brother DCVP-J125 manual reset
1.plug the power cord while holding the menu with in 16 seconnds to make the machine enter the maintenance mode.
2. Enter 8 & 0 by using the up arrow key & SET keys.
3. press the mono start key several times untill the purge count appears on the LCD.
4. enter 2 7 8 & 3 by using the up arrow key & set keys to reset the purge count to zero
5. press the stop/exit key to return to the initial stage of the maintanance mode.
6. enter 9 twice by using the up arrow & set key's to exit from maintenance mode
just follow the steps and hope you can do it......
I try it to my self before i post it and shared to others....thnx and GOD BLESS by Harry Technician.
Anonymous
  • Posted on Apr 22, 2013
SOURCE: brother dcp j125 unable to print 50 error
why dcp j125 paper jam
Anonymous
  • 3 Answers
  • Posted on Jun 30, 2013
SOURCE: my brother printer DCP-J125 cannot
Brother DCP J125 unable to init.af help me please.
How to troubleshoot ink absorber nearly full of brother DCP-J125 printer?
You can troubleshoot ink absorber nearly full of brother DCP-J125 printer by this pic:
pic-j3dvwh2n0uxx3mden3wfqrdd-3-0.jpg For the more details and other error information and troubleshoot visit the link:
https://www.manualslib.com/manual/622268/Brother-Dcp-J125.html?page=94
WHERE IS THE PURGE UNIT IN BROTHER DCP-J125 PRINTER?
Description Fails to switch the cap lift cam positions. Causes Cap lift cam switch defective ASF encoder sensor defective ASF motor defective Main PCB defective
How to reset unable to clean 50 error on brother dcp-j125? I cant open my printer brother dcp-j125 due to an error unable to clean 50.no paper jam occured.
You need to pres Menu-Mono Start-Up Arrow 4 times in less than 2 Seconds !!! and you will be in Maintenance mode. LEDs will be flashing. Press the Up Arrow and numbers will change and press OK after the one you want to select. The number sequence is the following. 8-0 2-8-6-4 4-4-6-0 7-7 9-9
DCP-J125 what is "machine error 31"
Paper jam, do a thorough inspection looking for any stuck bits of paper.
7helpful
Brother DCP-J125 unable print 73
unable to print 73 brother printer dcp-j125
Norman Weimar
Norman Weimar
k24674
