Question about Akai PT5598HD 55" Rear Projection HDTV-Ready Television
Can i fix fan no 2 - Akai PT5598HD 55" Rear Projection HDTV-Ready Television
Some of the fan blades on several fans are drooping how to fix? lost light in 2 of them?
What make/model of fan is it? Are they indoor or outdoor? Low end fans are made of cheaper parts, so remember, you get what you pay for. The only way to fix is to get new blades & maybe blade holders.
Apr 06, 2016 | Dryers
Where is "fan #2" in Samsung dlp hl-r5656w?
I don't know which is fan #2 but if you take the back off, you will see one fan right in front of you. The other is harder to get to. It's the black box inside the silver covering with the holes (in left lower part).
My TV was acting up by having only one color showing until I let it cool down then it would work fine. I cut a hole in the plastic back cover and mounted a bigger computer fan. Just spliced it in the wires of the little fan. Fixed the problem
Jan 26, 2013 | Samsung HL-R5656W 56" DLP HDTV
Newly installed Hunter remote will work light and fan if only 2 of the 3 bulbs are installed.
Did you install the correct wattage? If you put in 2-60 watt try 3-40 watt instead .
Dec 30, 2012 | Hunter 52" Ceiling Fan With Light And...
My televiosion hs a rattling sound, it displays cooling fan 2 but the sound goes away after a short period of time. I have had a repairman out but the problem still isnt fixed after tow visits
Hi.
The rattling sound is usually coming from one of the internal fans. The fan may make noise because one of the blades is broken, because of dust or foreign objects in the fan or because of a defective fan bearing. If the noise goes out after a while then the problem is likely a defective fan bearing. If display is indicating that there is a problem with fan 2 then fan 2 must be replaced even if at the moment of testing is not making noise.
Regards.
Ginko
Sep 10, 2011 | Samsung Televison & Video
We have a Frigidaire 2 ton heat pump. The condenser fan hums loudly but does not turn. It was running well until a strong rain storm with thunder and lightening. This is the 4th breakdown, all with...
yes its worth fixing!!!! Take something and give the fan a spin if it starts then you know its your capacitor that run the fan motor if it does not start then it is your fan motor. It will be cheaper to fix this unit then it is to buy a new one!!!!
Aug 20, 2011 | Frigidaire Heating & Cooling
Equium P200-1ED.
yes the fan can be changed before that your noise making fan can be fixed only you have to do is that unscrew the fan first take small brush clean the fan leafs and blow some air from your mouth to the bearings and motor part put a few drops of oil or 2-3 drops of oil in side bearings and slowly rotate your fan with your fingre to and fro so the oil can reached to the bearings and it will get lubricated wait for five mintues and fix the fan back in position and you can use it ot need to add more oil to it again add 2-3 drops thats all once the fan is lubricated it will not make any sound in the future this is applicable to all cooling fan it is must that once in a year you should lubriacte the fans for better perfomance and it will get more life too.....
Oct 12, 2009 | Computers & Internet
Fan spins for 2 seconds after rrod fix
u can try fixing by mircosoft or try the towel trick on youtube
Sep 07, 2009 | Microsoft Xbox 360 Console
Canon ir 400 photocopier
i have ir400 in my machine. first e805 code has been displayed and after that it shows that to load paper. then after e803 code is displayed. please help
Jun 03, 2009 | Canon imageRUNNER 400S Copier
Huntington Bay Ceiling Fan W/lights & Remote operated. # HD 361054
I had a similar issue with my fans. The fix I came up with was my remote was faulty. An easy fix because I had 2 fans with the same remote.
Jun 29, 2008 | Dryers
Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
22 people viewed this question
Top Akai Televison & Video Experts
KISHORE DESHPANDE
Ekse
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
