Canon PowerShot G9 Digital Camera Logo
A
Anonymous Posted on Jul 11, 2014
Why won't my powershot a1200 flash work? - Canon PowerShot G9 Digital Camera
Paul Green
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Canon Expert 527 Answers
  • Posted on Sep 02, 2015
 Paul Green
Canon Expert
Level 2:
Prodigy:
Answers
527
Questions
Helped
232752
Points
686
Have you enabled the flash function in the camera menu? Look for a menu item that says something like Internal Flash and follow that through
Thanks for the info. You mentioned factory reset. How does that work?
You should find the reset to factory default option within the camera's menu options.
Try this too: Remove memory card before resetting.
Turn off the camera, and leave the camera without inserting the battery & memory card overnight allowing it to reset.
1helpful
2answers
Black screen on canon powershot a1200 can see the symbols and takes black pictures
Did you try to press the display button several times? You then switch between different modes, while shooting and while playback. One of the modes is screen out.
5helpful
2answers
My powershot G9 built in flash is not working
There is a switch on the hot shoe to detect the external flash. When you use an external flash, the switch will be pressed down, then the unit will bypass the internal flash and won’t let it fire. If the little switch gets stuck somehow, you won’t get your internal flash on.
Check this switch on the hot shoe (either on the left side or the right side), blow some compressed air then plug/unplug an external flash several times. Hopefully you can get it back
Fix a1200
EMAIL ME AT [email protected] I HAVE A COUPLE OF QUESTIONS!!!
Motorola Phone Tools can not access to A1200 (System Memory is full)
It sounds like a bad flash or firmware to me. I would reflash to a different firmware. You can only flash to the same or a higher track with these phones, so be careful not to flash to a lower track. You could brick your phone.
A1200 bad flashing
I'm too...Please help me ? mail: [email protected]
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
