Chances are the batter is bad. Did you just purchase the notebook? You may want to try swapping the battery in your laptop with the other laptop you tested the adapter on. If you do need a new battery, here is a link
Game Boy Advance SP - Charging Light Won't Display
If the orange-colored charge light on your Game Boy Advance SP is no longer coming on when the A/C Adapter is connected to your system, please use the following troubleshooting steps.
Troubleshooting Steps:
Make Sure the Game Boy Advance SP Isn't Already Fully Charged If the battery is already fully charged, the light will not display when the system is plugged into the AC Adapter. Play a game without using the AC Adapter for at least 10-15 minutes, then plug the AC Adapter in, to see if the light comes on. If it does come on, the battery was fully charged. If the light still does not come on, see Step 2.
Make Sure the Outlet You Are Using Works Plugging another electrical device into the outlet is a good way to check if the outlet works, or that the outlet you are using is not controlled by a nearby light switch. You may also want to try a different outlet.
Try a Different Licensed AC Adapter If the charging light doesn't display, try a different AC Adapter, if possible, to determine if perhaps the problem is with the adapter.
If a different AC Adapter works, you will need to get a replacement AC Adapter from our Online Store, or by calling our Consumer Service Department at 1-800-255-3700.
If a different AC Adapter doesn't work, or if a replacement AC Adapter is not available and the lights will not display, we recommend having your Game Boy Advance SP repaired. Check out our convenient repair options.
Note: Please be sure to include both the Game Boy Advance SP and the AC Adapter with any repair
Yo! i think you should try something.get a friend that uses your type of adapter, try charge it with that and see if it responds.if it doesn't charge, you will have to replace your battery which means its spoilt.
Sounds like the battery might be bad. Try another battery in the laptop and see if it charges. If it does then you know the other battery is bad.
If you try another known working battery and it still wont charge, then try another AC Adapter. If you still cant get the laptop battery to charge then at that point the motherboard is bad because you will have tried another working batter and another working ac adapter.
If the laptop works OK with the acadapter, then the adapter is OK. Does the charge/battery light come on? How old is the battery? If the charge light comes on the battery is low power. If the battery is over 24months old and has been used in the laptop all that time, it is probably exhausted and need a replacement.
Hi, Remove the adapter and the battery from the laptop.
Press the power button and hold it down for 20 seconds(without the
battery or adapter plugged in to it). This process is called POWER
DRAIN.
Now connect only the adapter and try to turn it on.
If it starts up, there is no problem with the adapter or the laptop.
If it doesn't, it can be either the adapter or the laptop.
You will have to check it with a different adapter to confirm which one is faulty.
The second case is that the computer powers on only with the adapter.
Then you can put the battery back in and try powering it up.
If it doesn't work, try connecting the adapter too.
If still it doesn't work, its a faulty battery.
Sometimes after doing a power drain, the computer will work fine.
If you have any more issues, feel free to contact me.
