Lens cover will not completely close when camera turned off. It opens completely when camera turned on. Can it be fixed?
SOURCE: lens error/system error
I have successfully fixed the same error on a Nikon 2100 by dissasembling the camera and removing grit from the gears that drive the lens. However, if the camera has been dropped, I suspect that something has got dented or bent. It may be worth taking the camera apart to see if a gear has got dislodged.
I would warn you to be very careful not to get a shock off the flash capacitor inside the camera though. Also, it took me quite a while to put it all back together. It's not the easiest device to work on, a result of the very compact body (for its time!)
SOURCE: lens error
wheni go to turn on my camera it says"lens error"on the screen and wont turn on lens is "stuck"open.
SOURCE: Nikon S200 Lens stuck inside
I had the same issue with my S210, so after reading other people's advice to send it in to Nikon and since that was going to probably cost me as much as the camera itself I figured it wouldn't hurt to try a little something. The lens on mine was a hair off center or had been pushed in on one side (barely - looking at yours you may be able to tell which side) - mine was in my purse also. So, I took my handy dandy skinny prying instrument (normal kitchen butter knife) took the battery out to make it try to open again, then when I popped the battery in as the lens tried to push out I pried the side I thought was a little lower back towards center...I heard a little pop and it worked! The lens came all of the way out and it's all good.
So, use gentle hands and try if you want, but don't think I warranty this!
SOURCE: Lens Cover Error-Lens Cover will not open
You may have dust or some liquid blocking the cap from opening. Take a q t tip and clean cap. Use the q t tip to try to jar cap loose.
SOURCE: I was using a Coolpix L20 when the lens stuck open
I have a coolpix l20 the lens is stuck Iam looking for a repair manual? Would like to fix it my-self
