Heating element
SOURCE: Kenmore 70 series dryer works but no heat
check your power if one leg is down eg 110 to the motor drier will run but not heat if the heater is getting 110 but not the motor drier will do nothing check for a partial tripped breaker eg one side tripped but not fully just turn off and reset check outlet for 220 check power cord at terminal block for loose or burned cord unplug first lol if cord is burned just means it was loose when in stalled most of the time this promb is elec.
SOURCE: kenmore dryer 90 series model 66901692
heating element is located at the back of the dryer. if you can see a big coil of wires like a long spring laid back and fort to a duct , that is the heating element.
SOURCE: How do I replace the heating element for the Kenmore series 90 dryer?
let me know if you need help
SOURCE: cant find heating element for kenmore 80 series dryer
it should be in a housing mounted just inside the back panel. unlatch the housing from its mounts and the element slides out from the bottom
SOURCE: how to remove front panel from kenmore 90 series gas dryer
Gently pry top of dryer in front corner area. Disconnect door switch inside front. Remove 2 sheet metal screws from inside front. Let me know, Thanks, Sea Breeze
