Poulan Pro push mower, I need to replace fly wheel key but not sure how
You need to pull the blower housing off. Then remove the the starter cup from on top of the flywheel. Pry off the flywheel usually by insert a prybar under the flywheel pulling up while tap on the side of the flywheel. you will see the key in the center of the flywheel. after removing the old key, replace flywheel then insert key into grooves after you line the two grooves up.
SOURCE: Which kind of oil should I use for the engine of a Poulan Pro 6.7
Automotive 30w detergent oil. Do not use multi-grade
SOURCE: carburetor adjustment
it would be a lot easier if you take the cover off the top of lawn mower.
find the carb, it usually sits near gas tank, there should be a screw sticking out of it. tighten until it runs normal. also adjust the air intake/ throttle arm on carb
SOURCE: how to change oil in poulan pro 650 series model
Drain plug is under the motor. tip the hole machine back, (handle lying on ground) put something heavy on handle to hold it down, the plug usually is a 1/2 size wrench. Put a pan under machine to catch the oil. Take the drain plug out, drain oil, put drain plug back in, tighten it, and put machine back on all four wheels. Add oil. Take about 3/4 quarters of a quart. SAE 30 or 10w-30.
SOURCE: How do I change the oil on my poulan push mower?
First: Disconnect the plug wire from the spark plug. Safety first. Second, look under the mower deck where the crankshaft comes out of the mower (where blade attaches). Right next to the crank shaft should be a drain plug. Remove the plug, drain oil in a pan, replace plug, put mower back on level surface, and refill in the fill plug on the topside of the engine/deck. Don't forget to reattach the plug wire when you are done.
