Question about NRS Hoveround MPV 5 - Used Power Wheelchair
Does mpv5 have a rest button - NRS Hoveround MPV 5 - Used Power Wheelchair
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 53 Answers
There is no reset button.
Posted on Apr 02, 2015
6ya staff
SOURCE:
Trying to put a mpv4 controller on a mpv5 scooter for father in law. The 4 has a power seat and 5 doesn't. Look same inside but when connected it does not move are the little 18g
Hi if u are talking about the joystick controller they have two different part numbers possibility they r not compatible. MPV4 =E41-9247 .....MPV5 =E41-4233. .cheers
Jun 03, 2017 | The Health & Beauty
How to locate and replace a fuse or fuses in a Hoveround MPV5
Here is te user manual to replace the battery where you can also find the fuse:
https://www.hoveround.com/Hoveround/media/Document-Library/how-to-install-batteries-for-mpv5-mk3-power-chair.pdf
May 03, 2017 | Health & Beauty
Hover round mpv5 , what size wench to remove tire
To remove Drive wheel 15mm 17mm 19mm are normal sizes, to separate the split rim for tire replacement, 7/16, 3/8. I would use a socket set.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Mar 28, 2016 | Hoveround MPV5 Electric Wheelchair - Used...
Wt is the tire psi for mpv5 middle tire
The pressure is 50 PSI, but 45 PSI worked better for me.
Sep 30, 2014 | NRS Hoveround MPV 5 - Used Power...
How do you change batteries on hoveround mpv5 ?
Disconnect cables going from battery boxes to the control box. There is probably a catch that needs to be squeezed in, then pull and wigglt the connection block until it disengages. Release the straps over the battery boxes then remove batteries and covers. Lift up on the cover (you may need to push some cable back into the box) and put cover aside. Disconnect cables from batteries and attach to the new batteries. Same procedure, in reverse, gets you back to an operational MPV5.
Sep 27, 2014 | Hoveround MPV5 Electric Wheelchair - Used...
Foot rest on mpv5 won't stay up just flops down
There is a bolt and nut to tighten. Put a 1/2 nut drive tool between the front tire's 3 o'clock position and the tire fender. Tighten to add back the resistance.
May 21, 2013 | NRS Hoveround MPV 5 - Used Power...
How can I get a manual for the Hoverround MPV5?
If the power chair was stored for a while, the batteries may have gone bad. There is a gel inside them that needs to be put on a current regularly or it will solidify. When you connect the charger, you get a green light because it senses the batteries are full; unfortunately they are full of crud, not power. Try replacing the batteries to see if that solves the issue. You can probably take them to an auto parts store or Interstate Batteries to have them volt tested. The type of battery you need is a U1, 12volt, 33amp and you will need 2 of them.
Apr 29, 2010 | NRS Hoveround MPV 5 - Used Power...
NRS Hoveround MPV 5 - Used Power Wheelchair Logo
209 people viewed this question
Top NRS Health & Beauty Experts
Vitally Alcher
Norman Worley
Are you a NRS Health and Beauty Expert? Answer questions, earn points and help others
