You can find a PDF copy here: Bosch Classixx 5 Manual
SOURCE: Bosch Classixx 1200 Express wont spin!!!! HELP
Make sure that all the water has drained from the washer, if it has a filter, remove and clean, it is located behind a removable plastic panel at the front of the m/c, if it still does not spin, suggest you remove motor and check the brushes for wear, this is often the reason it won't spin, but will wash o/k.
Plz rate my solution.
Thanks
SOURCE: I have a Bosch washing machine /classixx 6 12 Expr...
Power on, press the start button for 5 or 6 seconds, the sign will go
off. Try the door gently.
Pl rate me 'very helpful' for the free help, thanks
SOURCE: bosch classixx 1000 express wont spin
Check the motor housing for an overload button, usually on the back and coloured black or red. Give it a push and if it clicks then the motor might have just been a bit stressed out and popped it.
Next two things are more serious unfortunately. The relay on the circuit board might have burnt contacts from switching the motor over the machines life, or, one of the motors windings has developed a fault. (these are both pretty rare though).
SOURCE: I have a Bosch Classixx
F21 is a motor or control board fault.
This also can be caused by voltage spikes or surges...
To reset it.
Turn the appliance knob to the off or reset position, 12 o'clock.
Turn the knob to the 6 o'clock position.
Press and hold the spin button.
While holding it, turn the knob to the 7 o'clock position.
Continue holding the spin button for about 5 seconds.
Release the button.
Turn the knob to off.
When your turn it back on it should have cleared the error code
If the problem continues then check the motor...
heatman101
SOURCE: Bosch Classixx 6 1200 express has an error code F21 what is it
it is a motor or pcb fault this is a reset code as follows,
turn dial to off 12 0clock position then turn to 6 oclock,
press and hold the spin buttonat same time turn it to 7 oclock,continue to hold the spin buttonfor 5 seconds,release button,turn off.
next time you turn on the error code should have gone ,
if it does not work go through the proceedure again i had to try it 3 times but it does work
