Question about Canon Rebel XT / EOS 350D Digital Camera
My Canon digital rebel will not autofocus correctly. My camera has 7 points autofocus, but it will only autofocus on the far right point. All other points are not used. I have had the camera for 14 months and the problem just began. If I want to focus on anything in the left to center of the field of vision, I cannot do it. However, the lens focuses manually very well. Why won't my camera focus on other points than the far right one?
  • 2 more comments
  • dave1959 Mar 13, 2008
    My Canon EOS Rebel XT will not autofocus, when I turn the switch to manual focus it still will not focus clearly. I deleted all the settings in case i accidentally changed something, but i can't get it to focus clearly at all.
  • picturecrazy Mar 16, 2008
    I have had my Canon Rebel for over a year now and have had my 75-300 mm lense for some times as well, and have always used the auto focus, and now all of a sudden it doesn't work. All it wants to do is focus in and out, but never to a clear focus, and will not allow me to snap a picture.
  • KlaatuBob May 22, 2008
    My Canon Digital Rebel won't autofocus any longer. None of the focus location red dots light up either. I've tried two different lenses (making sure they are in autofocus, not manual focus mode) and I get the same thing. First it adjusts focus all the way in one direction, then all the way in the other direction, then I get a green dot inside the lens and it won't take a picture. If I switch to manual focus I can focus fine and take pictures fine.
  • RodgerPM Jul 26, 2008
    I've a very similar issue.
    I was taking pictures when suddenly it no longer would do so. I finally switched to manual focus and it would again take pictures. Back on auto focus the lens (have tried 3) would focus in and out and then the focus conformation light would start blinking and no picture is possible. I've already tried setting the foucus points and it all was well with them. (I was using automatic settings in any case not manual.)
    I've downloaded the manual with no luch and searched the web. I'm open to suggestions to get this working again as I was just made the staff photographer for the youth sports league here in town and fighting with manual focus will make getting the best shots far more difficult.
I had this problem awhile ago - you must have accidently adjusted the focal area - it is sooooo easy to do without realising it. Here is what I was told:
Most likely, you have changed the AF point, which only takes effect in the creative modes (Manual, Av, Tv, P, etc)
There should be a button on your camera that has a grid like pattern above it, like
or so. press that, look through the viewfinder, and move the shutter or rear wheel, you should see the different AF points like up in red, and as you turn different ones will light up, and eventually all of them. also, you can look on the screen on top (or back, if its a rebel) and it will show you which ones are selected while in that mode, instead of looking through the viewfinder.
Posted on Dec 07, 2007
  • amandaw_98 Feb 22, 2011
    This totally worked. I have been searching all over, and I was so upset that my 1 year old Rebel was not autofocusing. Thanks so much, Cyberkitty!
    amanda
  • bendy36 Jun 22, 2011
    This worked immediately! Thanks a lot!
    Champion:
  • 217 Answers
It is possible that your focus sensors are dirty. remove the lens to the body and try to clean the mirror, open the mirror and clean the small glass ( around 7 pcs). Clean all the mirrors inside. Also check if there is dent or misaligned mirror.
As an amateur photographer, I always set my focus sensor in the mid section only.
Posted on Nov 12, 2007
Thank you cyber sitter...my problem was the changed AF point. The lens wasn't focusing most of the time...now it's right on...thank you, thank you, thank you. I was starting to worry that I needed a new camera. Now I can continue upgrading lenses. :)
Posted on May 27, 2008
  • monson_photo Oct 11, 2010
    This was very Helpful to me as well! I certainly cannot afford an upgrade now!! Thank you so much!! http://michellemonson.lenzus.com
    New Friend:
Im having the same problem. All of the lights on my AF point are red and still will not autofocus. My mirror seems to be clean and it won't even take one picture. HELP
Posted on Nov 25, 2012
    New Friend:
My Canon Rebel EOS XTI will auto focus but will take the picture. I have tried to take pictures in manual mode but still same results. Any suggestions?
Posted on Jul 19, 2011
Anonymous
SOURCE:
Why does my canon eos rebel t3 not take a picture when the shutter button is depressed but tje red eye reduction button keeps flashing and the video still works?
Usually, it means that the timer function has been turned on, and the camera is going through a countdown to trigger the shutter.
After that, it means that something else is not working correctly. If video works and records, then you know that the sensor and memory are functioning correctly. At that point, check to see whether your camera and lens are set for the form of autofocus or manual focus you want and that the aperture is still functioning correctly.
At some point, switch the camera to an all manual settings mode and try the shutter switch. If it still does not take a picture, the switch may have a problem.
Aug 18, 2014 | Canon EOS 1100D / Rebel T3 Digital Camera
Autofocus canon 600d
There is a seperate sensor for the autofocus. IT is either bad or dirty. You may not be able to clean it either.
Jul 18, 2012 | Canon EOS 600D Rebel T3i Digital Camera
In my Canon 4ood Even after i pressed halfway and the autofocus point has blinked to indicate focusing is done but focusing is not happening and the shutter won't fire.With manual focus i'm able to take...
If it is a dark scene and the camera cannot detected edges well the autofocus will either move around a lot or simply will not focus and thus wont expose. You will just have to manually focus or use the flash
Mar 01, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
Will a quantaray 28-105 1:3.8-5.4 Zoom lens Autofocus from a 35mm rebel ti fit on Canon EOS Digital Rebel 6.3 MP 300D?
The 35mm Rebel Ti and the Rebel 300D use the same lens mounting protocol. All Canon cameras designated 'EOS' use the autofocus EF lenses. If your Quantaray lens worked on the Rebel Ti, it will fit and should work on the Rebel 300D.
Mar 19, 2009 | Canon Digital Rebel / EOS-300D Body only...
Canon 400d constant backfocus
Backfocus problems will be magnified when using wide aperture lens with shallow depth of field, nice lens btw. Camera's adjustments for manual and autofocus are inside mirror cage behind mirror, and you dont want to risk getting dust on sensor or damaging sensor. Qualified camera repair shop or sending to canon for adjustment would be my suggestion.
Feb 27, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Autofocus jumps around and often will not settle on the correct setting
what i do is usually put it onto manual focus then back to auto focus, what it may be is that you are using the wrong lens for your subject :/
Feb 27, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon 300d autofocus problem
Have you choose a correct "Focusing Point" by pressing the right outmost button on the rear of the body, just above the CF card compartment door?
Feb 23, 2008 | Canon Digital Rebel / EOS-300D Digital...
Canon 400D. Autofocus problem
(facing the LCD screen towards you, as if you're going to take a photo) there's a button in the upper right-hand corner that will allow
you to AF to a certain point (9-pts total) or the center, or all 9-points, maybe you have it set to one point and it's off center??
definitely sounds like a camera setting probelm
just a thought
Feb 17, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
My camera cannot focus
Are both the lens and camera set to autofocus?
Jan 25, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Only one auto focus point
have you already pushed the focus point button - top right, under your thumb and then push the set button? Pushing the set button will flip between only the centre focus point and all 7.
May 06, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
13,415 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Ekse
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
