I had the same problem. I have the 40 inch Proscan and they supplied a remote control guide for comcast. It was only 4 digits and it did not work. I called Comcast and they did not know. I found it needed 5 digits so I added a 1 and it worked The code is 10178. Hope it works for you.
You mostly have to go through all the numbers to find one that works. Sometimes, with an off brand TV I have the best plasma i've ever owned right now. It's not a fancy brand name and the remote ( Comcast ) wont work for it. The comcast guy said that it would not work with my TV. Hope ite helps. You may not be able to pair the two at all.
I had the same problem and code 0178 worked for me. It isn't anywhere that the other codes are on the internet, I just found it on a message board somewhere.
I was having the same problem with my 40" Proscan Tv. I had to go to Comcast and get the remote with the gray OK button instead of the red. I could program my DVD player with a 4 digit code so this remote worked when I put in the 4 digit code Proscan sent with the TV (0178). This was the only solution I could find . They do have the remotes with the gray button but you might have to be very persistant to get one with the codes for the rest of your electronics.
Wow it took me a couple hours but hey i found the code ever1 needs and its a 5 digit code for comcast remotes with the red ok button the codes r 10090 or 10030 hope ive helped u out good luck
