SOURCE: how to change lexus es300 2002 cabin air filter
I just changed the cabin filter of my ES300. I found the instructions on the manual, under airconditioning and audio. It's pretty easy to do. I bought the filter from Kragen's for $21.95.
SOURCE: amplifier location 1993 lexus es300
My Son has a 95 es300, the amp for it is located under the front passenger seat. The easiest way to access it is to remove the 4 bolts holding the seat down, and remove the seat. Takes about 5 minutes
SOURCE: LEXUS es300 oil light stays on oil level full
Check oil level sensor, replace if necessary. also, does your engine knock or make a tapping sound?
SOURCE: a shop diagnosed my 99 lexus es300 and said my
Take a look at the two photos:
The second photo, the part is under the arrows:
SOURCE: cannot find thermostat of 99
1999 Lexus ES300 (3.0L, VIN F, 5th digit, 1MZFE engine)
Thermostat on 1mz-FE Engine
Fig. Correct alignment of the thermostat jiggle valve.-1MZ-FE and 3MZ-FE engines
Hope helps (remember to rate and comment this).
