SOURCE: GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
SOURCE: Dryer starts when start button is pressed and held but will not stay running when button is released
there is a holding contact at the motor wiring, check the schematics and trace that holding contact. it should hold the motor running as soon as it starts.
tnx 4 using fixya,
drcool
SOURCE: Kenmore gas dryer doesn't stay running have to hold button down.
POST MODEL NUMBER, BUT IT MAY BE THE MOTOR START SWITCH.
SOURCE: Press start button and dryshuts off when start button is released
There is a switch assembly on the motor that activates when the motor is running. Centrifugal switch. It keeps it running when you release the switch. That is where to start. Eric
SOURCE: My Kenmore Elite Total Care System with Evenheat
It sound`s to me based on your description, the start relay/switch is faulty. (the other unlikely possibility is the start switch in the motor).
If you call a local part`s supplier or check out searspartsdirect.com, apwagner, partsdepot, repairclinic etc. with your model & serial number, they should have that part for you.
Hope that help`s you. Please take a second and rate the information provided to you here at fixya.
Thanks for visiting fixya and good luck.
macmarkus :)
