Lands Phones Logo
A
Anonymous Posted on Jul 10, 2014
How do I change hold music? - Samsung Prostar 816 Phone
KX-T7730 phone is not changing the hold music although i have plugged in the mp3 player in the outside box, and tried to program it by doing the following: program > *#1234 > 104 > speaker phone...
If you're reading the programming instructions in order, keep going :-) I have no clue what SLT hold mode has to do with music on hold or background music, but when you get to 111-BGM-Music On Hold source, you can set it to external and you're in business.
Carl
1helpful
Can you change the "on hold" music on the
The music source plugs into the EXT MUSIC port of the Panasonic System cabinet. It could be one or two jacks on the side of the box or the MPR card. Whatever supplies the music would need to be reprogrammed. In the USA, it's illegal to play unlicensed music on hold without paying a fee.
Carl
2answers
HOW DO I CHANGE HOLD RINGING MUSIC?
The music is external to the phone system. In the back room or a closet somewhere, there's a dark blue and black cabinet that has a port that's marked MOH. It will go to some kind of box or computer that supplies the music. It may have a model or phone number on it. You change the music by buying or recording new MP3 files to play.
How to change the hold music on the panasonic kx
Back in a closet or electrical room, there's a back and blue cabinet with all the wires coming into it. That's the phone system cabinet. Your Music is plugged into a port labeled MOH.
When you get to that, it will be some sort of MOH player. Post back when you find it. If it's an On-hold product, there's a software program to change it.
Carl
Changing hold music - Panasonic KX-T7433
If it's truly music and not tones, the music comes from a device plugged into the system cabinet. On the side of the system there is a port marked MOH with a cable and a box at the other end. Here's where you find the MOH device and either change the CD or record new messages into it.
Intellitouch has a product called message studio that lets you make your own message on hold messages here:
hahttp://www.onholdplus.com/products/7000series_ms.html
The demo is free, and a licensed product is about $30.
Carl
How do you change the hold music on an NEC dTerm Series i ?
If you are listening to internal music on hold, it is done at the PBX. A general user can't change it.
2answers
Panasonic KX-T7730 Corded Phone
If you truly have music, it comes from a box plugged into the cabinet. The unit could be made by several manufacturers, or could be a CD player. If the talent is music with alternating male and female voices saying "thank you for holding we appreciate your business", etc. then it's probably an OHP-6000 that comes with Message software. http://www.onholdstore.com/software.html
If you have "tones" on hold, then you need to acquire a music on hold box and make a couple of programming changes to set it up. MOH boxes and messages can be found by search engine. The keywords on hold music will get you 19 million hits.
Carl
Can I change the on-hold music ??
The on hold music comes from something plugged into the TDA cabinet in the back room. Sure you can change it, but you have to find it first.
Such sources can be an On Hold device from Intellinet, A Premier box, or maybe a Nel Tech box or simply just a radio or CD player.
Once you identify what you have, post back here and someone can talk you through sources to change the message.
Carl
Change background music when hold button is pushed
There are two internal "tunes" that nobody likes. You can also set it to "tone," but that usually makes people think they have a call waiting - and they hang up on you!
We do offer license free music that you can plug into the phone, or you can subscribe to XM Radio (commercial) for less than $28 per month.
The settings need to be changed by a certified dealer.
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
2helpful
2answers
Your system will have an input for music. You may have something attached already and so that would need to be changed to what you want. OR you may be using a built-in internal tune. Usually connecting an external source will over-ride any internal music automatically but it may need to be changed in programming. If you connect a new external music system, you can use just about any music device with the right cable. Just make sure it is line-level input (low volume - not amplified) or you can break the music circuit.
Top Samsung Lands Phones Experts
Ngoro
john h
ADMIN Andrew
ADMIN Andrew
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
