Comdial Impact SCS 8212S Corded Phone Logo
A
Anonymous Posted on Jul 10, 2014
My calls go directly to voicemail on edge 120
Thong Nguyen
Level 1:
New Friend:
  • Contributor 22 Answers
  • Posted on Mar 02, 2015
Thong Nguyen
Contributor
Level 1:
New Friend:
Answers
22
Questions
0
Helped
20097
Points
42
Normally when calls go directly go to voicemail, there are a couple things why this happens:
- Extension are unavailable/busy
- Call forwarding/Do Not Disturb are on.
If you do have call forwarding/Do Not Disturb on, please consult your user's manual for detail instructions since there are several options for call forwarding (Forward All Calls, Forward Busy, Forward N/A, etc.).
How do I get voicemail of a Samsung s6 phone .
Samsung Galaxy S6: How to get voicemail (phone calls go direct to voicemail)
Hello.. 2 things we need to address here:
1. How to access voice mail account:
Access VM: Press 1:
Easy way to access your voice message system is to go to the dialer pad on your phone and press down on the "1" key until your voice messaging system announces
or you can dial your phone number to get to your voice mail
2. Change Call Setting, go to:
Dialer > (3 dots) Select Settings > Call > (scroll down) Select More Settings > Call Forwarding > Voice Call > then change to Always Forward (turn off)
How do I put a voice message on my phone when I am not available to take the call
Samsung Galaxy S6 Edge: How to put a voice message on phone when not available to take call:
Hello. If you did not set up your voicemail account yet..
Simply, on your S6 call your own phone number. When you do this it will ask you to set up your outgoing voice message.
Setting up Visual Voicemail
Visual Voicemail Samsung Galaxy 6 edge G925T
How do you check voicemail on the comdial 7260 edge 120?
There should be a voicemail/Vmail button on the phone. From there, you dial in the extension and password.
Why is it when I try to call certain num or anyone calls this num it goes to my voicemail
Your description of your problem is rather brief. Trying to read between the lines, I gather several questions:
Why is it when I try to call a certain number it goes strictly to their voicemail?
When somebody tries to call my number, it directly goes to my voicemail?
The general reason a call goes directly to voicemail is that your phone is off or in the area of limited or no cellular service. Normally if you are on the phone when someone calls, the phone notifies you that a call is waiting. However if your phone is off or in a fringe area or where there is poor cellular service such as in a large building, subway system or the like, calls to your phone are routed directly to voicemail.
The same applies if you call someone else. If there is no cell service to their phone or their phone is off, your call to them is routed directly to voicemail. You'll probably find this problem more common in rural areas where the cellular services poor, or in a large city with tall buildings that block cell signals such as in New York City.
Most SmartPhones also have the ability to send an inbound phone call directly to voicemail. This can happen several ways.
1. When the phone rings, and the user does not wish to receive the call, depending on the cellular operating system (iPhone, Android), the user may make a sliding motion on their touchscreen sending the call directly to voicemail. I do this a lot with unfamiliar numbers that are often telemarketers. Anybody that really wishes to get a hold of me will leave a voicemail message and I'll return their call.
2. Calls originating from contacts saved in your contact list may also be sent directly to voicemail. I have saved literally hundreds of phone numbers of telemarketers under multiple "telemarketer" contacts in my cell phone and sent them all directly to voicemail so I do not see bothered if they continue calling.
Hope this answers your question. If not, please clarify your question by providing more details.
How do you set the number of rings before phone goes to voicemail?
The ring count is determined by the voicemail system. The Edge 120 is a phone, not a voicemail system. What voicemail system do you have on your phone line?
I have a Comdial Edge 120. When a call is transferred to an extension and is not picked up at that extension within a certain period of time, it goes to that extensions voicemail instead of bouncing back...
I'm not familiar wiht Edge terminology, but the idea is you set the transfer recall time to something less than the call forward to voicemail. It means that any calls to voicemail have to be direct transfers and there may be some auto attendant issues.
HTH
Carl
Calls wont go to voicemail,call voicemail and get a busy signal
are u dialing ur voicemail by using direct dialing icon?
If so, u need to contact ur service provider and get the voicemail number , put that number in again. Enjoy direct dialing.
CP100 Auto Attendant transfers direct to voicemail
The norstar extension may be setup up for Call Fwd to voicemail, or call fwd/busy. Also, Custom Call Routing may be setup to send the caller directly to the mailbox.
HTTC 6800 Not receiving calls in sleep mode
You want to make sure your callforwarding is on. Sometimes when you select sleep mode, the calls will divert directly to Voicemail. Plus, ensure you have signal. Without signal, by default the calls go directily to voicemail. We won't wanna miss a call here. You can follow these steps here. start
settings
phone
services
call forwarding
get settings (wait for a while)
forward all incoming phone calls (check the box)
OK
OK
Exit
In the option to forward calls, there should be an option for the amount of seconds the phone RINGS prior to forwarding directly to voicemail.
IF your HTC device doesn't have the option for voicemail, and your calls are routed else where, contact your carrier for the voicemail number. This is very important!
Cheers!
Top Comdial Lands Phones Experts
k24674
ADMIN Andrew
ADMIN Andrew
omonat at engineer...
Level 1 Expert
Are you a Comdial Lands Phone Expert? Answer questions, earn points and help others
