Question about Panasonic KXDT333 Phone
I am getting a reordertone erroe message
I recently set up my Panasonic KX-UT133 phone to use a hosted PBX system the details were entered and save in line 2 - now I can receive calls but I get a reorder tone error when trying to dial out
6ya staff
SOURCE:
Anonymous
SOURCE: Almost constantly gives "no link to base" message
I had this problem too. I popped the battery out, waited 1 minute then put it back in. Unfortunately this clears the memory of all recent calls, etc. but it immediately started working again. So far its only happened once...
Posted on Mar 31, 2007
Anonymous
SOURCE: I cant make calls on my Kx-t7730 but i can recieve calls
sounds like you need to call a qualified tech
Posted on May 11, 2008
Anonymous
  • 113 Answers
SOURCE: Panasonic KX-T7433
These phones are digital proprietary telephones which means that they only work on panasonic telephone systems and not on normal analog lines. If you have a panasonic system the correct way is to plug the line into the " To Main Unit ", the handset into " Handset/Headset" and a normal analog phone into " To Tel ". If the wiring on the line jack was not done digitally the phone will also not work
Posted on Mar 19, 2010
Testimonial: "Thanks Heaps Buddy"
Anonymous
  • 113 Answers
SOURCE: I need help setting speed dials on a Panasonic KX-T7730!!
Hello, from the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle press Program * # followed by the system password ( default is 1234). Now press 001 and then SP-PHONE. Enter the system speeddial location ( 00 to 99 ) or just press SP-PHONE again to go to 00. Now enter your line access number ( usually 0 or 9 ) followed by the telephone number you would like to assign for the speeddial. Now press AUTO DIAL / STORE to save your setting. To go to the next speeddial location press SP-PHONE and follow the above steps again. Press Program to exit program mode. To dial the system speeddial from any extesion lift the handset and press * followed by the speeddial location ( example 00 )
PLEASE rate this answer if it was helpful.
Thank you.
Posted on Mar 24, 2010
boblate
SOURCE: no dial tone, rings but cannot answer
Turn off the mains power at the base unit for a few seconds, then turn the power back on.
Posted on Mar 17, 2011
FWD/DND will not cancel on KX-TDA200
Hello,still having the same problem?I can remotely configure and cancel call forward and configure your system as you want it.Contact me for help.
Mail me: omonat@yahoo.com
Make the subject be PANASONIC PBX
Aug 21, 2012 | Panasonic (KX-TDA200)
Hi , i have panasonic TDA100 ipbx system i recently buy kx-tda170 hybrid extension card and install to pbx how can create extension from 25aid cable
The 170 card is an 8-port DHLC and it's pinned exactly like the old 123211 and the TD series systems where the first 2 pairs are the voice and data for a Panasonic Analog phone or a single line set on the first pair, and the 3rd pair is unused in the TDA. There are 8 3-pair sets in the cable and the 25th pair is nothing. Here's a link to an installation manual http://public.carl.airpost.net/Pana/TDA/100_TDA_IM_07-04.pdf The instructions start on page 139.
Carl
May 05, 2011 | Panasonic KX-T7731 Corded Phone
Hello, I have 4 Panasonic KX-T7630 with TDA100, and I set the flexible button for CO or INT, but the LED on the buttons didn't light when I receive a call. I can make a call use this buttons, but the LED...
Whenyou program the buttons use the following steps -
press PROG
press the BUTTON to store
press 1 for an extension and the enter the extn no. followed by STORE
(or press 0 to store a line key)
(or 2 to dial an outside number dont forget a 9 for outside line access)
Aug 10, 2010 | Panasonic KX-T7630 Corded Phone
We want to transfer a call to a phone number (external party). System programming is required. Can you help me? Thanks, Gina
Panasonic KX t7730 call forwarding function to external party:
If you are using the Kx-TA624 pbx (TES 824 models) system, program your phone unit (t7730) as follows: lifet handset, press FWD/DND button, press 3, then the outside line access code, then phone number, then #, then return handset.
If you are using the kx-ta1232 (higher models) of pbx system (usually with 9 or more CO lines cabable, use the following command:
lift handset, press FWD/DND button, press 6, then the outside line access code, then telehone number, then # then return handset to cradle.
Jun 11, 2009 | Panasonic KX-T7730 Corded Phone
How to assign one telephone line for 2 sets in parallel? I have Kx T7730
This phone is a system phone. it is intended for use with a PBX, not to be directly connected to a phone line.Do not directly connect or you run the risk of damaging the phone.
Jun 09, 2009 | Panasonic KX-T7730 Corded Phone
I HAVE A PANASONIC PHONE SYSTEM TDA 100 HYBRID IP -PBX PHONE SYSTEM WITH PANASONIC PHONES KX-T7633 PHONES.WE HAVE NINE PHONES IN THE OFFICE AND I CAN ONLY GET 1 TO RING ON INCOMMING CALL HOW DO I GET ALL...
In program no (620) enter all the extension nos which you want to ring in group 1. Then in program no (450) enter the floating no of group 1. You will get the floating no in program no (623).
Mar 23, 2009 | Panasonic KX-T7633 Corded Phone
Change ringer tone
Message/Ringer Lamp: The Message/
Ringer lamp informs you visually that you
have a message or a call.
When you receive a call, the lamp
flashes depending on the ringing pattern.
When the ringing pattern is set to Single
(Slow flash), Double (Moderate flash), or
Triple (Rapid flash) in your PBX, the lamp
flashes. When the other ringing patterns
are set in your PBX, the lamp may not
flash. (e.g., S-Double, Call Waiting
Tone1).
When someone has left you a message,
the lamp is lit continuously.
Please note that the above indicates that ring patterns are set in the the PBX. These are issues that require a real person to sit at the main system and program the features that users need. I hope you have an I.T. person that knows your phone system. If you don't, you'll have to find a communications company in your area that can program your system. Thanks for using Fixya.
Jan 19, 2009 | Panasonic KX-T7730 Corded Phone
Setting the time on the panasonic KX-T7630
This is a PBX system, correct? If so, the fastest way would be through the PBX control computer. If you have a Panasonic TAW series PBX, I really like the AbleComm websites, search for your model PBX there.
Dec 06, 2007 | Panasonic KX-T7630 Corded Phone
Panasonic KXDT333   Phone Logo
129 people viewed this question
Top Panasonic Lands Phones Experts
Ekse
martin hogg
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
