LG V181 DVD Player/VCR Logo
A
Anonymous Posted on Jul 09, 2014
How to change regional code on dvd
How to Change area code on my dvd player
5 Related Answers
Anonymous
  • Posted on Jul 17, 2008
SOURCE: how to change area code on dvd player
I've tried one like this on mine which had the same problem and it workded.
go to this website for your dvd player (you can also search other dvd players on this site) http://www.videohelp.com/dvdhacks?dvdplayer=LG+V181+&hits=50
jaffa012001
L Jefferson
  • 376 Answers
  • Posted on Sep 09, 2008
SOURCE: break region code on lg lra-850
LRA-850 just fallow the instuctions
http://aiwaownersnetwork.tripod.com/pages/lg/5000_series_firmware.html
Anonymous
  • 1894 Answers
  • Posted on Oct 08, 2008
SOURCE: Update DVD to Region Free
your player is already a region free player
you need not worry
drlalitv
Lalit Varadpande
  • 488 Answers
  • Posted on Oct 29, 2008
SOURCE: How to change LG DP 170 DVD Area Codes?
you can make it region free by looking at this..do leave a rating if it helps..http://www.videohelp.com/dvdhacks?dvdplayer=LG+DP+170+&hits=50&Search=Search
i used their hacks on two players and they worked flawlessly!
Anonymous
  • Posted on Jun 16, 2009
SOURCE: I'm looking to unlock (or change) the regional code on DVD player
this didn't work for me is there another way? to make my dvd player region free?
1helpful
I have a sharp tv/DVD player when I put a DVD in it says region code error
Does it do this with all DVD's? Check in the menu settings for region codes - change it to region for USA area and it should work.
There are about four or five different region codes for the world. It is possible that the region code that came with your machine got changed over and ..........
Please advise how I can change area/regional code from usa to ausrtalian region
Yes , you need to change the code to AU, you can change it three times then it locks up.
Lg DVD player blu ray BP240
You will need to look in the owner's manual for the answer to this one.
Or look in the setup menu on the DVD player.
And on DVD players, it's not usually zip code. It's region.
If you are in the USA now, and the DVD player was set up for somewhere else in the world, good luck trying to change that.
The USA is Region 1. If the player is set to somewhere else, I don't know if you can change that.
If in the USA, try for Region !.
2answers
How do I Reset region codes Pioneer DVD-RW DVR-K17 ATA Device
this is atomatically set by your windows program,you can only change this 3-5 times, from control panel, check computer defaults,remove power for dvd and shut off computer, then connect dvd, power up and check again what region your using,when you in the region area clik ondvd and see if it will allow you to change if not then you can;t change it..
1helpful
2answers
I WANT TO CONVERT MY TOSHIBA SD501 KB DVD PLAYER INTO A MULTI-REGION PLAYER. HOW CAN I ACCOMPLISH THIS TASK?
On most of the DVD players regional set up cannot be changed.However just for trying; type your players brand and model number into goggle along with 'hack code' and you should be able to find some codes to change the region code on your player.You need to find the correct 'Hack' for your model.
Google 'DVD Hacks', there are many sites out there that will provide the details.
It generally consists of pressing a secret sequence of buttons on the remote.
Like holding the mute button down and simultaneously pressing 6758, they are all different.
It then enters a special mode where you can change the DVD region or make it region free.
In my experience the major brands like Sony, Sharp, JVC, Toshiba,Panasonic etc are harder to change, I guess the major players do not want copyright issues.
The cheaper DVD players as unbranded, or never heard of, are better.They are all "MULTI REGION " or "region free "players play any region dvd.
Take care and please Remember to rate/vote for us to
continue f
or Helping out the Community :)
additional info for DVD regions:
DVD region codes are a digital-rights management technique
designed to allow film distributors to control aspects of a release, including
content, release date, and price, according to the region.DVD video discs may be
encoded with a region code restricting the area of the world in which they can
be played.
The American DVD Copy Control Association in California requires that DVD-player
manufacturers incorporate the regional-playback control (RPC) system - according
to the Australian Competition and Consumer Commission, an Australian government
agency.
There are six different official regions and two informal variations.[citation
needed] DVDs may use one code, a combination of codes (Multi-Region), most
codes (Region 0) or every code/no codes (Region All). The commercial DVD player
specification requires that a player to be sold in a given place not play discs
encoded for a different region; however, region-free DVD players are also
commercially available.
1helpful
I cannot view some DVDs from other area than the one I bought the DVD player. Which is the area code to change or unlock the DVD area for LG 3D Blue Ray BX580?
HI,
Hi this player is multi region code free . There is no code region for this appliance. Please check other possibilities that cause your player malfunction.
Regards
2helpful
I bought 3 disney movies from the us can'play them on my dvd need a code area australian
Of course I cannot condone any solution contrary to any Australian, US, or international law.
Most DVD players offer the option to change the region code...
Please be aware that due to DVD piracy problems, every DVD player manufactured, regardless of who makes it or where it is made, allows a maximum (if at all) of THREE region code changes.
In your circumstance, this would mean that you can change your DVD player region code to region 1 (US), watch your videos, and then change it back to the AU region code...You would then be allowed one more change. If you attempt to change the region code after that, your DVD player would lock out and be turned into a paperweight.
As a "Yank" who has been to Australia (Perth NSW- twice!) I sympathize with your problem- wanting to have these videos forever and not being able to watch them at all....
The only "safe" option that I can offer is to surf the web for a program called DVD-Shrink, or something similar that will allow you to remove the region code from your DVD's, and set it to "region zero"...which will play the DVD anyplace, anytime. DVD-Shrink works as a copy program from a PC DVDR drive and can remove most region codes from a DVD depending on the disc- most is explained in the FAQ.
Please do not allow yourself to be duped into trying an "all regions" download for your DVD PLAYER. Every single one that I have received a reply about, after warning off the "customer" has resulted in a "my player does not work anymore" response!
2helpful
What does it mean when my dvd player says wrong region??
DVD's are coded to play in different parts of the world. Each DVD player is set up to recognise these codes. Most are set up to recognise only the region code of the area it was made for. For example Region 1 is for the USA and Region 2 is UK and parts of Europe. A DVD player made for the USA market would not be able to play any other discs with a Region code other than 1. And so on... This was done for the film industry benefit so that films can be released at later dates in different parts of the world without everybody seeing it on DVD issued in the USA.
However most DVD players can be "hacked" by a combination of keys allowing the user of say a Region 2 player to change it to another region. Some can also be changed to Region 0 which means it should play any disc.
How to change the Region code can be found by putting the model number of the DVD into a search engine and the words 'region code'. Some can be found on this site too.
2answers
My Sony Blu ray can't play normal DVDs in my region - Africa. How do I change the region coding just for DVDs?
It's not possible to change the region code in the Blu-ray Player.
BD media does have region codes. But, unlike current DVD players, the region codes for BD media use letters instead of numbers to indicate a particular zone or region where the discs can be played.
The BD region codes are as follows:
Region A: North America, South America, U.S. Territories, Japan, South Korea, Taiwan, and other areas of Southeast Asia
Region B: Europe, Africa, Middle East, Australia, and New Zealand.
Region C: Asia (except for Japan, Korea, Taiwan, and other areas of Southeast Asia)
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
