Pride Victory 4 Wheel Mid-Size Electric Scooter  Logo
A
Anonymous Posted on Jul 09, 2014
I need a wiring diagram for m Pride victory mobility scooter. Where can I get one?
Rob Hill
Level 3:
  • Pride Master 1,480 Answers
  • Posted on Jul 10, 2015
Rob Hill
Pride Master
Level 3:
Answers
1480
Questions
0
Helped
517187
Points
3838
Hi sadly you won't however i can help , what's the problem ?
Regards
Rob
www.gewizrepairs.co.uk
5 Related Answers
Dan Hudson
  • 119 Answers
  • Posted on Nov 27, 2008
SOURCE: Pride victory mobility scooter
1. Remove the four screws on the outside perimeter of the console base.
2. Lift off console top cover and disconnect the front-to-back cable.
3. Remove the throttle lever from the throttle pot.
Remove the four screws holding the console base to the mounting plate.
Anonymous
  • Posted on Jun 22, 2009
SOURCE: Need a wiring diagram for Pride Rally Electric Scooter
I can tell you how i fixed it for $19.95
oregoon
  • 175 Answers
  • Posted on Jul 07, 2009
SOURCE: THE SCOOTER MAKES A HIGH PITCH NOISE WHEN THE KEY IS TURNED ON
The buzzer is a piezo-electric device that is the "horn" for the scooter. It also will alert when the scooter is in reverse, if this option is programmed into the scooter. It receives its power from the PC board or console board which is located inside the top of the shroud at the tiller, where the thumb paddles that direct the scooter are located. If liquids have reached the board, or if condensation has affected the board, the circuit that controls the buzzer may have shorted causing it to come on constantly.
Opening the top of the shroud is fairly simple. Remove about 6 screws holding the clamshell cover together, remove the speed adjust knob, and it should come apart. Inside you'll see a PC (printed circuit) board, green in color with lots of small electronic parts embedded on it. The buzzer is also inside, usually about the size of a marshmallow and black in color with tiny holes to let the noise escape. There will be two wires leading from the buzzer to the plug-in at the PC board. Unplug the buzzer and the noise will stop, but you won't have use of the "horn" at all. Replacing the PC board can be done by a certified Pride tech, but it will probably cost you about $150.00 for parts and labor.
Hope this helps.
oregoon
  • 175 Answers
  • Posted on Aug 28, 2009
SOURCE: I have no manual for my Pride victory mobility scooter
http://www.pridemobility.com/pdf/owners_manuals/US_Scooter/US_Victory_10_om.pdf
Click on this link and a pdf manual for a Victory 10 will appear.
Anonymous
  • 17 Answers
  • Posted on Nov 09, 2009
SOURCE: Need Wiring chart for Revo 4 Pride Mobility
I have wiring chartfor Revo if your interested
Pride Victory XL-4 Mobility Scooter
You can get then from Prides website
Wiring diagram for a victory pride 9
Hi I found this type in .google search....,victory 9 wiring diagram ..good luck
2answers
Controller flashes 9 times what does that mean
Basic Troubleshooting Instructions - Pride Mobility Products
www.pridemobility.com > Resource Center
Pride MobilityINFINFB2468 Jazzy 614/Jazzy 614HD with Dynamic Controller Troubleshooting ... LiftChairs. INFINFB2061 Basic Troubleshooting Instructions: Lift Chairs ...
Pride Mobility Products Corp. - Product Owners Manuals ...
Pride MobilityHelp Me Choose · Where to Buy · Request to Be Contacted · View all Models. Pride Mobility Scooters ... Power Chair Consumer Safety Guide .... Version / Date. Flash. C 01/04. Pride LX Series. C 05/08. Z-11. B 07/04. Manual Wheelchair ... Travel Scooter Throttle Control Lever Operation Product Insert ... Victory 9/Victory 10 ...
Troubleshooting / Repairs Mobility Scooter, Power ...
I need a wiring diagram for my Pride victory 3 wheel scooter. Where can I get one mine is all messed up?
Try spinlife.com or call them at 1-800-850-0335. Maybe Customer support or manuals, technical assistance.
Pride mobility victory XL front tyre wear
Is your track rod bent or out of alignment? Carefully buy the exact wheels with tyres and a track rod if necessary from dismantled Victory XL scooters (a good wheel with a good tyre about €30 - I've done that for my Pride Celebrity XL8 - it was a great success.
I have a victory pride mobility scooter the battery is fully charged and it won't run I tried to reset but nothing worked
Have the controller module checked. You can also download the service manual from Pride's website. It has a lot of information in it as well as a complete wiring diagram.
2helpful
Battery charger not working. A white wire that connects to the AC plug has become disconnected. Can soldering it back on work okay?
yes this is a common problem on a victory scooter i know i have one and the same problem just solder it up carefully
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
