Question about Panasonic KX-TG5632 Phone
How to set phone on silent - Panasonic KX-TG5632 Phone
Phone is stuck in silent mode
Press and hold the pound key (#) until it exits silent mode.
Here is the original text from the manual of the phone:
"Quickly Switching to Silent Mode
Silent mode is convenient when you wish to stop the
phone from making noise, in a theater for example.
In Idle mode, press and hold the "#" key until the “Silent
Mode” message and the Vibration icon display...
To exit and reactivate the previous sound settings, press
and hold the # key again until “Exit Silent Mode” appears.
The Vibration icon no longer displays."
You can also download the pdf file for the phone's manual online by simply googling "Samsung x427m pdf manual."
Hope this helps!
Mar 13, 2010 | Samsung X427M Cellular Phone
Silent profile alarm Nokia E71
go to profile activate silent mode in the settings alarm mode vibrating
Jul 15, 2009 | Nokia E71 Smartphone
Somehow i have turned the silent mode off on my phone, and i have tried everthing to activate the silent mode back on and it doesn't work. can anybody please help me.
or by holding down the # key :) you may have changed the profile itself, so check under profiles > Silent check the settings in there are actually set to silent...
May 08, 2009 | Nokia 6500 Slide Cellular Phone
Cant figure out how to set my phone to vibrate or silent!!
is it a cell phone? if it is, then try holding down the # key. usually * locks and # sets to vibrate.
Apr 29, 2009 | Lands Phones
How can I make the mobile silent while someone calling
Depends on your model. Most mobile phones will go into Silent mode if you press and hold the # key.
If not then it'll be displayed in your phone settings. Most phones have a Settings tab and the silent mode feature can be enabled/disabled in the 'Sounds and Alerts' section.
Apr 20, 2009 | Lands Phones
Hi Does anyone know if you are able to set the ringtone to silent and also the incoming message tone to silent (need it for work) on the Samsung F480 Thanks Elkay
In order to set the ring tone to silent you must turn the volume down to silent or vibrate. Go to phone in menu and check on sounds.
Jan 04, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Nokia 1600
if you hold the hash key down for a few seconds, it should come off silent, but if it doesnt check your phone settings to find if your got you ringtone set to ringing or if its off, either way, it should all be in your settings.
Jul 25, 2008 | Nokia 1600 Cellular Phone
Nokia 6300
hi, have you tried enter setup then profile then select general this should then set your phone back to normal if not then instead of going to general go to silent and change the settings under the silent profile, like turn ringtone on and select ringtone.
Try the first option first as this is quick and easy failing than then just change the settings under the silent profile then you can even change the name from silent to general then you can change one of the other profiles to silent so try it then get back to me if you need further assistance ok
Apr 25, 2008 | Nokia 6300 Cellular Phone
NOKIA 6131 CANT GET OFF SILENT
have u tried manually going into your settings in your phone and selecting settings and profile and selecting another profile but silent? only suggesting.
Nov 30, 2007 | Nokia 6131 Cellular Phone
Panasonic KX-TG5632 Phone Logo
Top Panasonic Lands Phones Experts
Ekse
martin hogg
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
