We use NEC MT1065 and just replace its lamp but it still won't switched on (lamp indicator led is red). How can I reset it ?
Hello, unfortunately the NEC MT1060 - MT1070 series projectors have EEPROM chips built into the lamp housing which counts the hours that the lamp has been used for so the only way to reset the hours is to change the lamp for a new one, if your old lamp has only had the reflector replaced then it will make no differance because the chip tells the projector weather or not to power up depending on the hours its counted, i have not yet found a way to reset the chips even by reprogramming them, i'm afraid the only solution is to replace the lamp with an official NEC unit, but this was obviously their intention, just as an added note, a solid red lamp indicator light means that the lamp has expired, if its flashing red this means its nearing the end of its life, if the status indicator light is flashing then there could be another issue, by counting the flashes you can reffer to the manual in the troubleshooting section to diagnose the fault, I know this is very late, but anyone else reading this may find it helpfull.
