Televison & Video Logo
A
Anonymous Posted on Jul 09, 2014
Code for 42pj550 to tune tv - Directed 434MHZ Remote Control
2answers
Need codes for Clear Tune Universal TV remote for a Clear Tune 13 Flat screen TV and how to program
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
My LG 42PJ550 TV tries to switch on, but won't power up
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Im trying to program a Panasonic universal remote to clear tunes tv
Search Results
    Need codes for ct-300 clear tunes universal remote - Fixya
    www.fixya.com/.../t17341079-need_codes_ct_300_clear_tunes_universa...
    Mar 26, 2013 - need codes for ct-300 clear tunes universal remote Need codes - Symphonic ST419E TV ... Universal remote code for a panasonic ct-27g14a.
    I have a clear tunes tv and trying to program my RCA universal
    www.fixya.com/support/t25649135-clear_tunes_tv_trying_program_rca
    Apr 16, 2015 - ... a clear tunes tv and trying to program my RCA universal remote to it ... "I need to program an old Panasonic TV with a RCA universal remote ...
    I need the codes to a clear tunes remote for a rca - Fixya
    www.fixya.com/support/t3026751-need_codes_clear_tunes_remote_rca
    Sep 26, 2009 - I need the codes to a clear tunes remote for a rca tv. ... "I need toprogram an old Panasonic TV with a RCA universal remote model RCR311St ...
    Radio Shack panasonic remote control codes clear tunes tv ...
    www.fixya.com > ... > panasonic remote control codes clear tunes tv
    ...remote. the panasonic codefor my radioshack 3-in-one remote is 0250 I need a codefor a VCR Durabrand (DCV603) for the Sony universal remote control or a ...
    Clear tech tv 4 digit code - TV - Other Consumer Electronics
2answers
How can I buy a remote control
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability.
Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
Type in the "brand name only" of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Forgotten password for lg 42PJ550
Try LG's website - they probably have a section where you can enter the serial; number, answer some security questions and have the password mailed or emailed to you. Same with their helpline.
Cant remember how to tune it in
  1. Turn on your TV.
  2. On your Tune In remote, press TV and release.
  3. Press and hold Set until the green light on Tune In blinks once, pauses and then blinks twice. Now release the Set key.
  4. Enter the first three-digit TV code for your Sanyo from the list which follows:
    154, 159
    These codes are listed in order of popularity, and the green light will blink twice if you perform this procedure correctly.
  5. Aim Tune In at your TV and press Power. Your TV should turn off. If it does not, repeat steps 2-5, trying each code listed in step 4 until you find the one that operates your TV.
Now Test Your TVWhy test? Many times more than one code appears to work. Testing is desirable to be sure you have the correct code for your TV or the other devices you are setting up.
  1. Press the Power key to turn on the TV, then press mute, channel scan ("CH") and volume ("VOL") keys. Tune channels 7 and 11 by entering the number followed by the Enter key.
  2. If your TV does not pass the test, return to Step 2 at the top of this page. Enter the next three-digit code and repeat the process.
I cant tune in my tv its a sharp dv5103h abd i have lost the manual
Dear customer,
Sharp TVs often require you to press the TV Tuning preset key which is a yellow function key.
   Setting Up Your Sharp TV
Turn on your TV.
  1. On your Tune In remote, press TV and release.
  2. Press and hold Set until the green light on Tune In blinks once, pauses and then blinks twice. Now release the Set key.
  3. Enter the first three-digit TV code for your Sharp from the list which follows:
    093, 165, 039
  4. Aim Tune In at your TV and press Power. Your TV should turn off. If it does not, repeat steps 2-5, trying each code listed in step 4 until you find the one that operates your TV.
U can also refer to the following link for ordering manuals  http://www.aerialsandtv.com/tvservicemanualsmainpage.html
Plz rate this solution..
Need a remote for Symphonic tv
should be171,179 or 180 Turn on your TV.
Enter the first three-digit TV code for your Symphonic from the list which follows:
171, 179, 180
Now Test Your TV
1helpful
3answers
Code for panasonic tv
ineed the code for a panasonic ct-27sx12af
Top Directed Televison & Video Experts
ExpressFiX
ExpressFiX
john h
Are you a Directed Televison and Video Expert? Answer questions, earn points and help others
