0xc0000005 error is one of the errors a PC user can face. This is a
critical access violation error that needs a quick response. If this
error is not addressed immediately, this problem might destroy the
computer system. Because this error relates the computer memory, there
is a huge tendency that you are going to experience computer freezes and
slow down. The Windows operating system will run slow because of some
system defects.
The best way to speed up a slow running computer is to clean it for viruses. Also optimize your system, browser and registry using some reliable cleaner such as Reginout Cleaner.
strange. with 4gb of ram, it should be fast. try to install better version of windows like win 7. it could help you. just don't install vwindows vista cause is slow as hell. let me know if it worked
Applications on the blackberry do not close when opened, each application you open consumes memory. Also the working memory and the memory to store programs are shared unless you have installed a microSD card. Remove and reinsert your battery, if a hard reset speeds the phone up your problem is open applications. If it does not, your problem is that you are out of space and need to remove some applications or install a larger capacity SD card.
Check whether this is not a viral slow down. If not i suggest this
1. Give enough space to the hard drive. 2. Uninstall unused application for a long time and not needed anymore. 3. Install Ccleaner, this can clean your registry, cookies, and other junk files. 4. Defragment your drive. If you have enough space already.
